Replacing Fuel Sending Unit - JeepForum.com
post #1 of 7 Old 06-29-2004, 02:57 PM Thread Starter
asutherl
Group
I have the infamous bouncy fuel gauge so I was going to replace the Fuel Sending Unit. I assume this unit is on/in the fuel tank.
Any advise from someone that's done this would be great. Part numbers and/pics would also help.
Thanks
Andrew
Andrew@universalrally.com
asutherl is offline
post #2 of 7 Old 06-30-2004, 06:10 AM
900Steve
Andrew,
for my 94 ZJ, the fuel sending unit was part of the fuel pump, in the tank. depending on your year/model it may be the same situation.
i supposed if you're going to do all the work to drop the tank, and you have high miles, you may just want to replace the fuel pump as well if you're 100% certain it's the sender (and assuming it can't be fixed cheaply)
-steve
4.0L, 94 ZJ
900Steve is offline
post #3 of 7 Old 06-30-2004, 01:06 PM Thread Starter
asutherl
thanks
thanks steve
yeah, it's a 1998 GC. I have access to a lift but was hoping i didn't want to drop the tank if I didn't have to.
If anyone has replaces the sending unit before I'd love to hear the war stories.
Thanks
Andrew
asutherl is offline
post #4 of 7 Old 06-30-2004, 01:11 PM
Buddha_Kip
Buddha_Kip's Avatar
screw all that dropping of the tank BS. do the Swampy Bypass Mod instead. You'll be MUCH happier.
2000 WJ Limited - 2.5" Rusty's springs WAAG 1-piece front brush guard custom built WAAG nerf bars PIAA 580 lighting Custom Paint One-off Aluminum Treadplate Door Entry Guards & Rear Bumper Step
1986.5 Porsche 928S - 18" Moda MD1 Autothority Chips Rear Muffler Bypass Short-Shift Kit
Grease Monkey & HNIC @ Clasik Auto
Buddha_Kip is offline
post #5 of 7 Old 06-30-2004, 01:16 PM Thread Starter
asutherl
good idea but....
Thanks for the link!
The only issue is that it's not my car, I'm doing it for a friend!! I don't think she'd like me cutting holes in her rig! If it were mine, no problem!
Thanks again! I used in-line pumps on my race car and prefer them!
Andrew
asutherl is offline
post #6 of 7 Old 06-30-2004, 02:52 PM
greasefingers
greasefingers's Avatar
1994 ZJ
Yep you got to lower the gas tank. I did mine without a lift; I just jacked the rear up a bit to allow the tank to swing down. I live in the North East, so the two hanger bolts were rusted on. I used a hacksaw blade in my hands to saw them off. You can access the worm clamps on the fuel tank fill-tube & vent line without removing the rear tire. Once the tank is removed you can wipe the inside of the tank clean. I paid $308.00 at my local parts store for a replacement gas pump/sending unit.
Cheers Steve
94 Black Laredo 4-Liter with QuadraTrac (42RE trans & NP249 TC) 200,000 + miles purchased new
88 Cherokee 2-door with 5speed manual 139K miles(deceased) purchased new
greasefingers is offline
post #7 of 7 Old 06-30-2004, 03:08 PM
900Steve
exactly. jacked the rear of the jeep up on stands, and dropped the tank. paid about $300 for the pump.
overall, the job wasn't nearly as tough as i thought.
4.0L, 94 ZJ
900Steve is offline
Backwards oil pressure after replacing sending unit? gonzo350 WJ Grand Cherokee Forum 10 12-17-2010 02:43 PM
4.0 possible fuel injector problem or fuel sending unit metroman ZJ Grand Cherokee Forum 2 08-15-2009 02:37 PM
question about sending unit and fuel pump mad_skillz ZJ Grand Cherokee Forum 4 12-02-2008 11:24 PM
fuel pump / sending unit seal. fortieri ZJ Grand Cherokee Forum 2 11-03-2003 11:19 PM
Fuel Pump/Sending Unit sbilcheck ZJ Grand Cherokee Forum 1 03-04-2002 11:23 AM
