Replacing fuel door release cable - JeepForum.com
post #1 of 5 Old 01-27-2005, 10:51 AM Thread Starter
99Yota
Well first off, hello. Based on my name, you can see I'm not a jeeper myself, but agreed to help a friend out. He has a 95 GC and his fuel door release cable seems to have broken. So he's been driving around with the fuel door open for the past couple of months. Anyway, he's got the new cable. Just wondered if anyone had any tips or had done this procedure before. I've searched here, but didn't find any results. Anyone know how much of a PITA this is gonna be? I haven't looked at it to see if it's routed through the cabin or underneath the rig even. Anyone who's done this, I would be delighted to hear any tips you might be able to offer. Thanks!
-Kyle
99Yota is offline
post #2 of 5 Old 01-27-2005, 12:18 PM
PlatinumZJ
Senior Moment Member
PlatinumZJ's Avatar
-Kyle
Welcome, I can't help directly, but that should be in the factory service manual (FSM) for the '95. I belive the cable release fuel door was discontinued in 96 and its not mentioned in the '97 fsm.
Doug
When all is said and done, more is said than done.
Platinum '97 ZJ LTD, I6 (see profile) Paid for!
Links:
for ZJ & WJ stuff,
for performance stuff. I6 performance info at
Other stuff: Kevin's Roof Rack. KOR sliders, Bored 62mm TB, Blaupunkt Bermuda w/ ipod, Brembo Slotted rotors,
OME steering stabilizer, H4 headlight upgrade...
PlatinumZJ is offline
post #3 of 5 Old 01-27-2005, 03:10 PM Thread Starter
99Yota
Well, thanks for the welcome and the advice. I unfortunately don't have a FSM, I would imagine however it would be in there. Thanks for checking yours.
99Yota is offline
post #4 of 5 Old 01-27-2005, 03:31 PM
Meerkat
It's not on the '96's either, but the bosses are there. I believe the cable is routed internally, and that in order to reach the area you want (back of the filler door area) you are going to have to remove the spare tire and the body trim panel. In order to remove the body trim panel, you have to remove the top and bottom trim pieces at the liftgate, the upper pieces of the 'B' and 'C' pillars, the rubber bumpers behind the spare tire (10mm socket) and the philips head screws holding the 'D' rings in.
HTH
Warren
Black 1996 5.2L ZJ Limited
Meerkat is offline
post #5 of 5 Old 01-27-2005, 04:33 PM Thread Starter
99Yota
Thanks! I kinda imagined that would be the direction I'd be going (interior panels). I do appreciate it.
99Yota is offline
Replacing a ZJ door iananderson17 ZJ Grand Cherokee Forum 2 04-06-2009 08:37 PM
Fuel System Pressure Release Method? pzappa ZJ Grand Cherokee Forum 2 01-02-2009 08:57 AM
hood release cable snapped :(...HELP!!! jeepunlimited ZJ Grand Cherokee Forum 3 11-06-2007 01:02 PM
gas door cable 95_Laredo ZJ Grand Cherokee Forum 9 01-28-2007 11:51 AM
Hood Release Cable mmain ZJ Grand Cherokee Forum 1 08-03-2006 02:57 AM
