replacing front suspension and steering - JeepForum.com
post #1 of 7 Old 09-22-2012, 08:52 AM Thread Starter
coralman
USER OF PARTS CATALOGS
coralman's Avatar
Need some help deciding what order to do this. Everything is going to be replaced but I know issues pertainig to the axle shifting ect have to be taken into account. The only thing I'm keeping is the springs, but I'm replacing the jounce bumpers and upper spring cushions. I just need the best order to proceed. Balljoints, hubs, first. Drop swaybar and trackbar to get droop enough to change the bumpers?
Then control arms one side at a time and then tie rods? Does this sound about right?
Originally Posted by HighLonesome
coralman is offline
post #2 of 7 Old 09-22-2012, 09:22 AM
newfieZJ
You're gonna need a few stands and jacks . You'll want to support the jeep on the frame rail right behind the lower CA mount , also the axle
Pull steering off the jeep , leave it for last to reinstall with new parts .
Starting on one side , remove tire/caliper/rotor/axle lock washer , pin and nut/3 bearing bolts /bearing /axle . Replace ball joints , re-install with new hubs .
Drop the track bar at the axle side , disconnect both end links . Disconnect shock from lower mount . Remove spring retainer . Lower the axle on that side with the jack . You might have to pry down on the axle , but the spring shouldn't take much more that a few prys to get it out from there . I would think now would be the time to replace the CA's . No spring force and you should have decent freedom to reattach things easily .
Pry bars are your friend if you don't have a compressor . With everything dropped as said , the spring will have little pressure on it , it won't fly off anywhere
Soaking the whl bearing bolts with a penetrant is a bonus always .
Some things I'm sure you already have and know . Just thought I'd go into some detail
1995 Orvis build
1988 MJ build
1998 Slate 5.9 build
1998 Platinum 5.9 build
newfieZJ is offline
post #3 of 7 Old 09-22-2012, 10:05 AM Thread Starter
coralman
coralman's Avatar
Thanks for the quick reply Newfie. Yeah I have about half the stuff already. I don't feel like shuttling stuff to a welder cause I know the caliper slides are shot so I'm getting new knuckles. Mines a 2wd and I'm kinda slow so I'll ask this again since visualizing it is giving me a problem. On the 2w they use a dummy stub shaft. It just pulls against the hub when drawn in by the hub nut? What does it do in relation to the knuckle? Forgive if this a stupid question but I don't know if I'll have to get the stub shafts as well.
coralman is offline
post #4 of 7 Old 09-22-2012, 10:37 AM
Montaska
Montaska's Avatar
You probably already know this, but just in case... Borrowing a tierod puller from the auto store will make life a lot easier. Good luck! Please document!
1997 ZJ: Sold | 2002 WJ: Sold | 2007 JK: Sold | 2016 KL: Current
Montaska is offline
post #5 of 7 Old 09-22-2012, 10:53 AM Thread Starter
coralman
coralman's Avatar
Got one already. Thanks for the help. Yeah I will probaly post another long a** thread with pics that will bore everyone,lol.
coralman is offline
post #6 of 7 Old 09-22-2012, 06:20 PM
MaintMech
Old and in the way
MaintMech's Avatar
I've always liked your "long AZZ" posts. You make good sense and make it easy to understand.
Looking forward to it, keep up the good work!!
'96 Grand Laredo, 4.0, Stock, Daily Driver
I fought Oracle and Oracle won!
Originally Posted by coralman
If the faith isn't there,the doubt is.
MaintMech is offline
post #7 of 7 Old 09-22-2012, 06:54 PM Thread Starter
coralman
coralman's Avatar
I'm humbled,thank you. Coming down with the flu I believe, feel like crap all day.
coralman is offline
Front Suspension/Steering Upgrades? WiscBadgerRN ZJ Grand Cherokee Forum 4 02-19-2012 12:34 AM
replacing the suspension rockstrmental1t WK Grand Cherokee & XK Commander Forum 2 01-02-2012 07:14 PM
Replacing Worn Suspension And Steering Components iPlay1515 ZJ Grand Cherokee Forum 13 09-20-2010 07:02 PM
ZJ Front End Suspension/Steering replacement Zoso ZJ Grand Cherokee Forum 4 08-25-2006 03:15 PM
Replacing suspension bushings? shudog ZJ Grand Cherokee Forum 11 02-03-2005 01:28 AM
