Replacing the driver door window - JeepForum.com
post #1 of 3 Old 06-18-2013, 09:57 PM Thread Starter
vonericsen
Has anyone on here replaced the driver door window?
Mine shattered yesterday and I just got done cleaning out all the glass from the door.
It looks like I need to slide the new one in and put the nuts on that hold it to the mechanical track that raises and lowers it.
Is it really that easy or will I end up having to do something else to get it in place?
Moss Green 95 5.2l ZJ- 5.5" IRO lift, 255 75 R17 BFG M/T on JK Moabs, Mopar ECU, Mopar Tire Carrier
vonericsen is offline
post #2 of 3 Old 06-20-2013, 06:15 PM
coralman
USER OF PARTS CATALOGS
coralman's Avatar
You have to remove the channel run to get the new one in. Raise the regulator until you have access to the nuts through holes in the door under the door panel.
Originally Posted by HighLonesome
coralman is offline
post #3 of 3 Old 06-20-2013, 07:01 PM Thread Starter
vonericsen
Thanks! I found the nuts but wasn't sure about the channel. Hopefully i can find a window intact at the junkyard this weekend
