Replacing compace spare with full sized spare. - JeepForum.com
post #1 of 11 Old 10-11-2013, 03:58 PM Thread Starter
artemis5
Hey guys! I have a question regarding my 1997 ZJ.
Awhile back, I replaced the compact spare with a full sized spare. The threaded rod that secures the tire to the wall is barely long enough to protrude thru the black plastic retainer so I can get the wing nut on it. It works, but barely. I have perhaps 3 or 3 threads engaged in the wingnut. I am concerned as to whether this is secure enough to withstand the forces of a crash and keep the tire in place. I'd sure hate to catch a spare tire with my head during a crash.
I also found that to make the switch, I had to remove the threaded rod from the hole in the sheet metal flange that holds it to the wall and re-install it from the other side.
My questions:
1. Safe enough, or not?
2. I know some of these Jeeps came with full sized spares. I saw one of them at a junkyard yesterday. (I assume that it had a full sized spare because of the vinyl cover. The actual spare was missing). I found that the threaded rod from that Jeep did not give me any more length than mine does.
3. Is there a different set of parts for mounting a full size spare vs. a compact spare?
Thanks!
artemis5 is offline
post #2 of 11 Old 10-11-2013, 04:09 PM
PolkaPower
Which way is the tire facing? I have mine with the front of the tire/rim facing away so the back of the rim is facing outward. I have the threaded rod going through one of the lug nut holes and then I have a ratchet strap holding it down also.
PolkaPower is online now
post #3 of 11 Old 10-11-2013, 05:17 PM Thread Starter
artemis5
Here's how I have it mounted. Inside of wheel facing outwards. Plastic retainer in center hole.
I probably have a few more threads engaged than I thought.
artemis5 is offline
post #4 of 11 Old 10-11-2013, 05:24 PM
PolkaPower
Yea you have different rims too so it works for me but I think you need a longer eyebolt. Just go to the hardware store and buy one.
post #5 of 11 Old 10-11-2013, 06:56 PM
AnotherRedZj
Jus loose the retainer and run it through a lug hole like polka. I have it the same way with oversized tires. The "wing" nut will secure it fine. should free up some thread space.
AnotherRedZj is offline
post #6 of 11 Old 10-11-2013, 07:15 PM
AnotherRedZj
Sent from AutoGuide.com Free App
post #7 of 11 Old 10-11-2013, 07:21 PM
PolkaPower
Originally Posted by AnotherRedZj View Post
That how I have mine with a strap going across. Works great.
post #8 of 11 Old 10-11-2013, 07:33 PM
AnotherRedZj
I'm gonna have my buddies girl make me a tire cover with a pocket to utilize that space inside the wheel there! Straps at stuff.
post #9 of 11 Old 10-12-2013, 10:14 AM Thread Starter
artemis5
Well, I found that I actually have more threads in the wingnut than I thought. Seven complete turns to remove the wingnut. Looks like the entire metal insert is engaged. Maybe this setup was designed for both compact and full sized spares.
I didn't realize until taking the photo how dirty my spare tire was. Going to clean it today.
Thanks for the replies.
artemis5 is offline
post #10 of 11 Old 10-12-2013, 05:32 PM
LouC
2007 WK
Right after I bought the ZJ in 98 first thing I did was get a full size tire on a steel OE Cherokee style rim. No problem with tightening the retainer. I guess I should get a new spare tire seeing as how it's 15 years old LOL!
2007 WK Limited Hemi QDII
1998 ZJ Laredo 4.0 Selectrac
LouC is online now
post #11 of 11 Old 10-13-2013, 03:28 PM
pageman
i was able to fit my full treadwright crawler through the middle of the hole and whith factory retainers but my rims are the old flat star. only issue i have is the rubber rubs just a little on the trim and leaves marks but i dont care. i have this jeep almost vertical on climbs and rock crawl and it never moves or makes a peep. i have tried various style gc rims and some are easier than other to use whith the plastic retainer and wing
pageman is offline
