Replacement radiator - JeepForum.com
post #1 of 7 Old 02-24-2007, 11:10 AM Thread Starter
eagleknight
2014 WK
I clicked over 200,000 a week or so ago, but have been having some transmission fluid leak from a line connection at the transmission cooler in the front. I pulled out the radiator this weekend so I could get to those lines and it has signs of leakage. Also the fluid level slowly goes down in it. I want to put a replacement in while I have everything apart. I did some searching on the forum and people have suggested radiatorbarn.com
My question is what is the difference between the two row and three row? If I buy the three row will have have any minor modifications that need to be made?
eagleknight is offline
post #2 of 7 Old 02-24-2007, 03:26 PM
Turbonut
I purchased my 3 row from radiators.com, but many have used the site you mentioned. Get the 3 row and no modifications will be needed during the installation. Just remember to move all the air dams over to the new rad, even the one on the bottom so as air is forced through the rad, and not around.
Those little 90 degree hose connections are pretty neat to access as I need to do the wife's when warmer weather arrives in a few weeks. Purchased them from NAPA but sitting in the garage for now. On her's, it was just some seepage at a hose connection, so I moved it down slightly and no more leaks.
Turbonut is offline
post #3 of 7 Old 02-24-2007, 09:48 PM Thread Starter
eagleknight
2014 WK
Of course mine was leaking from the bottom hose that is nearly impossible to get to. I ended up drilling two holes through the plastic piece that is behind the grille that the lights attached to access bolts. They get covered up anyway when the grille is put back on. That made it so when I took the radiator out and unbolted the transmission cooler it slipped up far enough to access the bottom line.
post #4 of 7 Old 02-25-2007, 12:31 PM
kentman
kentman's Avatar
2006 XK Commander
I had the transmission fluid leaking from the wrench fitting at one point. I found that it had worked itself loose over time. I just cranked the wrench fitting down, and the leak was gone.
Regarding the radiator, mine died at 198K miles. If you are at 200K already, then a swap is probably in order. I have used radiator barn a couple times, and I was very satisfied. I went with an OEM equivalent. The shipping was crazy fast. I am now 16K miles down the road, and I have no leaks and no problems with cooling.
'06 XK Limited, 5.7L, QD II, Black, 163K
'02 WJ Overland, 4.7L HO, QD, Inferno Red, 126K
kentman is offline
post #5 of 7 Old 02-26-2007, 06:52 PM
Gramps
The Necessary Evil
Gramps's Avatar
2007 MK Compass
Replaced the Radiator and Trans hose on the wife's '96 last July, 160 K miles. The local NAPA store got a radiator from a sorta local re-builders outlet, no shipping charges. I could find out what the company is if interested. Also got the upper trans hose with the slip on fitting that goes to the bottom of the radiator, BK 827-5350. Redesigned fitting. No leaks and no problems.
Bob
posts 68 & 69
Also visit me at
Gramps is offline
post #6 of 7 Old 02-26-2007, 08:27 PM
FPKites
ZJjazzyJim
FPKites's Avatar
If you offroad at all, I would avoid the 3-row. That extra row can make it a bit restrictive when airflow if in question. If it's a street Jeep...towing, lots of highway, no rockcrawling, the 3-row would be good.
Radiator Barn is great - CSF is the brand they carry, and it's all metal instead of the craptastic plastic tanks on the OEM. Very sturdy, and they do ship extremely quick. No leaks whatsoever out of mine.
Jim Karlin
"Duh! Big RED Jeep!!!"
or
96 ZJ Laredo
5" lift, Claytons, KOR radiator support, rear bumper, steering brace, etc, etc, etc.
04 WJ Overland
Clean.... :D
FPKites is offline
post #7 of 7 Old 02-26-2007, 08:29 PM
ajmorell
ajmorell's Avatar
I actually just had the dealer do mine (it sucks, but I don't have the tools or time at school to do it), and the radiator itself was only $120 and has a lifetime warranty on it, so I'm fairly satisfied.
ajmorell is offline
Please help - 96 ZJ radiator replacement dmm219 ZJ Grand Cherokee Forum 2 06-21-2009 12:30 PM
Replacement Radiator Tigggger ZJ Grand Cherokee Forum 3 02-24-2009 07:41 AM
radiator replacement 2002WJGuy ZJ Grand Cherokee Forum 9 11-07-2008 05:17 PM
radiator cap replacement tonysailor ZJ Grand Cherokee Forum 2 07-25-2006 10:00 PM
WJ Radiator Replacement? TPI Monte SS ZJ Grand Cherokee Forum 5 01-11-2006 11:25 PM
