Replacement power antenna mast? - JeepForum.com
post #1 of 20 Old 11-09-2005, 07:09 PM Thread Starter
MAUSS
Is the mast of the power antenna on a '93 GC Limited replaceable? If so, who carries them? I can hear the motor running when I turn the radio on and off, but it's stuck about half way up.
'93 Limited (sold), '96 Laredo
MAUSS is offline
post #2 of 20 Old 11-11-2005, 11:38 AM Thread Starter
MAUSS
Anybody? I can't believe I'm the only guy in here with a bad antenna.
MAUSS is offline
post #3 of 20 Old 11-11-2005, 01:17 PM
guango88
Air Trans
guango88's Avatar
are you looking for stock or universal, if is the non retractable they are a little hard to find unless u go to a junk yard or ebay, I personally replaced mines to a retractable one do to the kids in the neighborhood sword fighting if you are interested look up Crutchfield.com or give them a call they are very helpfull
Good luck
ONE ABOVE ALL
guango88 is offline
post #4 of 20 Old 11-11-2005, 01:53 PM
Phil Gerard
Former Mod
Phil Gerard's Avatar
I had to go to Jeep to get mine.
Phil
'95 ZJ Ltd. White 4.0L
TW DC DS; ARB Bull Bar, F&R Air Lockers; Superior Axles; Warn Winch; 4.56 gears; ACOS, Addco F&R Sw Bar, JKS Discos, Rr Track Bar & Nerfs, 249>242 Swap, Stillen rotors+Kolak pads, 3 pc. Armor, RE 4.5 Kit + 2.5"BB, Adj. UCAs&LCAs, OME SS, Bilstein 5150s, 15x8 AR Diamond Backs, 33 Truxus MTs, K&N FIPK, RE 62mm TB, Perf. Distr. 4.0L Kit, Exhaust: 2.5" Kolak exhaust FM 70: Optima Yellow, Mean Grn Alt., PIAA 520s, 540s, Kevins Rack, & TB Conversion
Phil Gerard is offline
post #5 of 20 Old 11-11-2005, 03:30 PM
ChicagoGuy
Team XBOX
ChicagoGuy's Avatar
Got mine from Jeep too - the gears on the orginal one got stripped, so it wouldn't go fully up or down. Sounds like you have the same problem.
(Insert Viagra joke here)
Happened about five years ago. Not real expensive a fix, at least at the time. A lot cheaper to just replace it than try and fix it.
- Bill (formerly VetteDriver)
ChicagoGuy is offline
post #6 of 20 Old 11-11-2005, 06:10 PM Thread Starter
MAUSS
Yeah, I'll have to try the local Jeep dealer. Crutchfield would be easy too... I live about 2 miles from their company headquarters (off of the same road actually) and I'm 5 miles from one of their two outlet stores. I was hoping I could just replace the mast part... I did that on a Volvo I owned once when the nylon track inside broke.
MAUSS is offline
post #7 of 20 Old 11-11-2005, 06:20 PM
OH-ZJ-IO
OH-ZJ-IO's Avatar
This guy bent over backwards for me when I had two 94 ZJ masts that didn't work any longer but didn't have, from the factory, 94 masts...both had the 95s and then we found out one had a 95 but without the sleeve.
I had purchased, from him, 2 94 masts, and he worked with me over 2 weeks to make sure I got taken care of. Got replacements and didn't cost me a dime.
Easy to change out. $14.95 plus shipping and 5 minutes of your time to install.
Al
http://cgi.ebay.com/ebaymotors/Power...QQcmdZViewItem
Check him out.
OH-ZJ-IO is offline
post #8 of 20 Old 11-11-2005, 11:21 PM
kellen
My fix was to find a fixed antenna at the junkyard and hammer it into the power antenna part. Mine was stuck completely down and I think broken off.
Schucks / Autozone wanted 65 for a power antenna. Didn't even want to check out the dealer.
Kellen
kellen is offline
post #9 of 20 Old 11-12-2005, 08:42 AM Thread Starter
MAUSS
The mast on Ebay that OH-ZJ-IO posted looks like the kind of thing I used on my Volvo. The was easy since you could access the antenna from the trunk. I wonder if anyone makes one like that for a 93. Thanks.
MAUSS is offline
post #10 of 20 Old 11-12-2005, 10:06 AM
OH-ZJ-IO
OH-ZJ-IO's Avatar
Hey!
I PMd you.
That guy has masts for just about everything. The ZJ masts run 93-94 and then 95-up as far as style/type is comcerned. He definitely has one for your application. I just posted that link because it was the first I saw for him.
Get on eBay and do the 'ask seller a question' thing and ask him.
He'll take care of you. And like I said...it's $14.95 plus like $5 shipping and you've got your replacement.
Did you not get the PM?
Al
OH-ZJ-IO is offline
post #11 of 20 Old 11-12-2005, 01:23 PM Thread Starter
MAUSS
OK, just noticed the PM. Thanks, I'll ask about it.
MAUSS is offline
post #12 of 20 Old 11-16-2005, 05:45 PM Thread Starter
MAUSS
It turns out that he did have a couple of 93-94 power antenna masts for sale. I bought one yesterday for $14.95 + $5 shipping. Thanks
MAUSS is offline
post #13 of 20 Old 11-16-2005, 07:06 PM
Woody
Retired back to Bowties
Woody's Avatar
1985
Pep boys sells them and it's only $14.95 as well. I have been putting mine off for awhile, but it still goes all the way up, just not all the way down.
Woody
1985 1 ton K-5, Detroit diesel, 36" tires (going bigger when money permits), 4-speed manual swap, Rockwell T-case, Hybrid lift, 12.5K winch.
Woody is offline
post #14 of 20 Old 11-16-2005, 07:36 PM
anticrombie
anticrombie's Avatar
was the power antenna optional? I've just got the unmovable sword type.
Charlie
anticrombie is offline
post #15 of 20 Old 11-16-2005, 08:00 PM
Woody
Woody's Avatar
1985
They quit using them in 96 I think. They are a bigger pain than they are worth. I'd rather have a solid mast.
Woody
Woody is offline
ZJ Electric Antenna Mast Replacement Tyrefryer ZJ Grand Cherokee Forum 11 08-22-2013 05:20 AM
Need solid mast antenna Baldman902 ZJ Grand Cherokee Forum 4 12-10-2009 04:03 PM
cant get antenna mast to pull in a70eliminator ZJ Grand Cherokee Forum 21 02-06-2008 04:19 PM
antenna mast replacecment alivenkickin28 ZJ Grand Cherokee Forum 5 02-14-2007 09:38 PM
Power Antenna Replacement??? arthur6 ZJ Grand Cherokee Forum 5 10-27-2002 10:07 PM
