replacement key for grand cherokee - JeepForum.com
post #1 of 15 Old 02-28-2005, 08:28 AM Thread Starter
TimTJ
Hey, a friend of mine has a 2000 grand cherokee, and he had new keys cut for it. They will start the jeep, but it turns right off. The original key still works. I know some keys have a chip in them, but this original looks like a regular key! Please help!!
TimTJ is offline
post #2 of 15 Old 02-28-2005, 08:39 AM
askoop
He probably has the chip in it. My chip key head looks very similar to a "normal" key with a rubber head.
You can get it programmed at your local dealer. Some lock smiths can do it, but you have to have at least 2 programmed keys to program another one (at least that is how it is at one of my local lock smiths).
BTW- the shutting down is how the chip keys are supposed to work... starting and then shutting down after a few seconds...
-Adam
His: 2000 WJ, 2.5" BB, mx-6 shocks, Rancho 5000 Steering Stabilizer, 245/75/16 MTRs, 1" addco rear sway bar, 9005 fog upgrade
Hers: 03 KJ, 5-speed, 245/70/16 General HTS
WTB: 1 Timberline wheel or a set of JK steelies
askoop is offline
post #3 of 15 Old 02-28-2005, 08:53 AM
Lurch77
He needs a chipped key. Most locksmith shops can cut and program them cheaper than a dealer. I never needed two keys at a locksmith. If you already have two good keys, you can program a third key yourself, no need to pay a locksmith.
Also, your friend may get the check engine light soon. The computer stores the info showing that a bad key was tried. At least mine did after a new chip key I tried did not take the programming correctly. If the light does show up, you can reset it by disconnecting the battery for a few minutes.
2001 WJ Laredo
4.0L, Quadra-Trac II
Lurch77 is offline
post #4 of 15 Old 09-10-2013, 12:09 AM
tjude
What if there are not two keys? I lost a key and need a replacement. I don't really care if the chip works or not. I just want to be able to start the car.
tjude is offline
post #5 of 15 Old 09-10-2013, 06:42 AM
MeanGreenZJ
What if there are no keys at all?
MeanGreenZJ is offline
post #6 of 15 Old 09-10-2013, 07:28 AM
RagTagSoldier
RagTagSoldier is offline
post #7 of 15 Old 09-10-2013, 07:30 AM
dnuccio
Holy thread revival batman!
Reliability is relative
R.I.P. Ratmonkey
dnuccio is offline
post #8 of 15 Old 09-10-2013, 07:50 AM
Jeeples
Jeeples's Avatar
They have these wonder people called 'Locksmiths' where I come from. They do all sorts of magical things like cut and program RF keys for Jeeps.
Also, if you want the vehicle to run for longer then 3 seconds, you'll need a key with the chip in it.
Keyception!
His: '00 WJ 4.7 Limited- Some stuff
Hers: '03 WJ 4.7 Laredo- Some more stuff
Originally Posted by wjjeep19 View Post
It is what Jeeples has *PARTIALLY* stated.
Jeeples is offline
post #9 of 15 Old 09-10-2013, 08:01 AM
xcaliber81
ppl need to see dates before they post a 2005 thread wont net you much help your almost better off asking a question in a new thread.
xcaliber81 is offline
post #10 of 15 Old 09-10-2013, 08:35 AM
RagTagSoldier
Keyception!
You literally just made me spit coffee all over my desk >.<
Sent from my iPhone using JeepForum so it probably looks goofy.
post #11 of 15 Old 09-10-2013, 01:07 PM
MeanGreenZJ
I let some people touch some of my things, my cars aren't one of them.
Keyception!
post #12 of 15 Old 09-10-2013, 02:34 PM
Jeeples
Jeeples's Avatar
And now this makes sense:
Originally Posted by pinky2252s
And yes mean green we all know you bought a key cutter and can cut keys. Cool? Doesn't make you smarter than me.
Jeeples is offline
post #13 of 15 Old 09-10-2013, 02:58 PM
MeanGreenZJ
I just wanted to know if anyone on here knew how to DIY the problem.
post #14 of 15 Old 09-10-2013, 03:31 PM
coralman
USER OF PARTS CATALOGS
coralman's Avatar
Keyception!
Damn, thought I was watching the wizard of OZ for a minute there.
Originally Posted by HighLonesome
coralman is offline
post #15 of 15 Old 09-11-2013, 01:31 PM
MeanGreenZJ
Grand Cherokee 5.9 Electric Fan Replacement bandanaboyz ZJ Grand Cherokee Forum 17 09-09-2013 04:44 PM
96 Grand Cherokee 4.0 Radiator replacement flinthills76 ZJ Grand Cherokee Forum 4 03-08-2009 03:23 AM
Need replacement key for 06 Jeep Grand Cherokee fountaik WK Grand Cherokee & XK Commander Forum 1 09-08-2008 10:21 AM
95' Grand Cherokee Evap replacement alivenkickin28 ZJ Grand Cherokee Forum 6 04-07-2007 04:00 PM
99 Grand Cherokee transmission replacement. Steeda WJ Grand Cherokee Forum 2 12-17-2003 07:27 PM
