Replacement Armored Brake Line - JeepForum.com
post #1 of 19 Old 09-19-2007, 07:44 PM Thread Starter
wingless
wingless's Avatar
1994 ZJ
The armored front-to-rear brake line on my 94 Grand Cherokee failed. It is not available from the dealership. The local shops would fabricate this, but without the armor.
An on-line search revealed Fine Lines would re-create the original, in either steel w/ stainless spiral wrap or stainless w/ stainless wrap.
A Dremel cutter wheel, at an angle, resulted in an acceptable shipping box length, for sending it to Fine Lines. I also painted one side, prior to the cut, to ensure proper orientation.
The replacement line arrived and I am very satisfied. I selected stainless line w/ stainless wrap. The Jeep uses metric fittings, so this is compatible with MB vehicles. It needed to have the shipping bend straightened and some other minor shipping smoothing.
Old Line - Master Cylinder End
New Line - Master Cylinder End
Old Line - Axle End
New Line - Axle End
94 Jeep
The stainless brake line with stainless armor has been installed.
The brake line was close to the original, but it still required a coupla hours to change the shape to match the original.
Thank goodness I took LOTS of shots of the original. The images were captured at multiple orientations and angles. I would match my view of the new line to that on the image, then adjust the line 'till it matched.
Even with the tweaks required, I am still very satisfied with the service and the product.
New Line Installed - Steering Column Not Replaced
New Line Installed - Axle End
The only problem was the rotational mis-registration between the front and back ends. My recommendation is to use the Dremel wheel to score a longitudal mark, along the brake line, prior to the cut, to ensure a better rotational match of the ends.
They also have replacement heat shield, that I did not utilize. I had them re-use the original.
Last edited by wingless; 08-18-2017 at 10:13 PM. Reason: Replaced PB extortion w/ Flickr
wingless is offline
post #2 of 19 Old 09-19-2007, 07:53 PM
blovingier
blovingier's Avatar
How much did that all run you? They look like pretty high quality lines.
"GRITZ"
99 Jeep Grand Cherokee Laredo - Totalled
-3" lift w/Bilsteins - - - - - - - - - - - - - - - - - -30.5" Pirelli Scorpion ATRs
07 Compass (wife's ride)Sold
-Stock
blovingier is offline
post #3 of 19 Old 09-19-2007, 08:00 PM Thread Starter
wingless
wingless's Avatar
1994 ZJ
The quality is top notch and they warrant my recommendation.
wingless is offline
post #4 of 19 Old 09-19-2007, 08:29 PM
blovingier
blovingier's Avatar
I will definitely keep them in mind. I'm considering replacing all my brake lines and hoses, so this was very helpful. Thanks.
"GRITZ"
-Stock
post #5 of 19 Old 09-22-2007, 06:25 AM Thread Starter
wingless
wingless's Avatar
1994 ZJ
For the rear, the long line from the ABS to the axle hose is the only one not available from the dealership. The two armored lines on the axle and the axle hose were obtained from the dealer.
So far, my front on mine are fine.
wingless is offline
post #6 of 19 Old 09-22-2007, 02:26 PM
blovingier
blovingier's Avatar
Cool, thanks. Good to know. Mine probably don't need it, but I'm just crazy about keeping everything with the brakes in good shape. I had a line fail on the highway once and from then on have had a sort of crusade against brake failure on my vehicles. Some of my lines have a few rust spots starting, so it's time to look at replacement for me.
"GRITZ"
-Stock
post #7 of 19 Old 09-22-2007, 02:39 PM
gunthagunth
gunthagunth's Avatar
why not use normal stainless brakeline?
97 ZJ 5.9L 242/4.5" RE Coils/1.75" Spacers/Clayton arms/Addco's/RE brake lines/35x12.5 bfg muds/Currie steering/K&N/Claytons Front Drop tracbar/Dropped pitman/Bilstein 5125's/JKS BPE/JKS loop conversion/JKS Sliders/ZJilla rear bumper/Clayton front winch bumper/durango steering box/warn 9000i/Hambek Customs carbon fiber cowl hood #2of16/Hp30-8.8 4.56/ARB f+r
gunthagunth is offline
post #8 of 19 Old 09-22-2007, 02:41 PM
blovingier
blovingier's Avatar
It'll keep my brake lines from getting an STD.............
"GRITZ"
-Stock
post #9 of 19 Old 09-22-2007, 06:45 PM Thread Starter
wingless
wingless's Avatar
1994 ZJ
That is an option. This information shows how to replace the factory armor brake line with armor brake line. This is the only source I found. As previously stated, I would recommend this company to others.
A replacement steel or stainless brake line, without the armor, will work just fine.
wingless is offline
post #10 of 19 Old 09-22-2007, 07:28 PM
BradMB2004
nice jeep!
@ work we sell Fine Lines, Right Stuff, and In-line Tube. call the other two and see what they say. "usually", if they currently do not offer a replacement, they will use your line to build a part# off of and ship you the first set for free.
all 3 companies are top notch and well sell thousands of $$$$ worth of each each month.
if you need a good contact at each company i can hook ya up.
cutting isn't really neededfor shipping. if you can just put a good u-bend in the line and mark it, that will allow them to streighten it out in a fashionable manor. That's how fine lines ships the F>R fuel and brake lines.
Brad
2004 Wrangler X
2001 Grand Cherokee Ltd.
1997 Grand Cherokee Ltd.
BradMB2004 is offline
post #11 of 19 Old 10-01-2011, 09:04 AM
9496ZJs
Paging Wingless...You still there?
Can you confirm if the flare fitting where the line connects at the front to the ABS Pump is a double-flared or a bubble-flare?
9496ZJs is offline
post #12 of 19 Old 10-01-2011, 10:21 AM
leadfootny
Yes all three fittings off the pump are bubble flares. NAPA sells fittings to convert the bubble to flare so you can make all the lines yourself. Be aware tho that all 3 fittings are a different size...at least they were on mine.
96 ZJ 4.0
98 ZJ 5.9
leadfootny is offline
post #13 of 19 Old 11-03-2013, 10:46 PM
9496ZJs
Resurrection on the old '96 ZJ brake issues
Well here I am again about to replace the Front brake lines...as well as the entire rusted out axle assembly. (Control arms ripped out the brackets).
So what the heck was Chrysler thinking when they ran the front passenger line up the firewall BEHIND the panel at the ECU????
Crazy routing. This is going to be a pain in the arse.
9496ZJs is offline
post #14 of 19 Old 11-14-2013, 07:18 PM
Rosslato
1994 ZJ
I'm so confused! I have a 94 ZJ 4.0 and need to replace the hardline from the rear but can't see where it goes up into the engine bay so where exactly does it go, to the ABS or to the MC? If to the ABS which line is it? Thanx
Rosslato is offline
post #15 of 19 Old 11-14-2013, 08:34 PM
somebody5788
1994 ZJ
Goes to the ABS but I don't know which one it is.
This is a good option for individuals I guess. Much quicker for me to just build my own line though since I have the flaring tool.
2006 Honda 919
1994 Jeep ZJ
2007 Nissan Titan
1997 BMW 328is
somebody5788 is offline
New calipers/brake line/pads, bled brakes, now i have no brake pressure! klwong1 ZJ Grand Cherokee Forum 13 11-16-2013 09:15 PM
Lowest steel line on frame rail, very rusty, brake line? ktmjeepguy ZJ Grand Cherokee Forum 12 10-08-2011 10:47 PM
97 zj brake line replacement warrior23 ZJ Grand Cherokee Forum 1 05-11-2009 08:26 PM
Replacement Fuel Line QM2Rick ZJ Grand Cherokee Forum 3 08-17-2008 05:27 PM
transmission cooler line replacement jimbo2 ZJ Grand Cherokee Forum 2 05-02-2002 10:09 PM
