Replacement advise for 96 ZJ - JeepForum.com
post #1 of 9 Old 07-24-2011, 10:55 PM Thread Starter
Fredthecat
It's time to replace the 96 I6 JZ Grand Chreokee Larado with 160K miles. More than got my money's worth, paid $6K in 2003.
Any advise what year/trim ZJ would make a good replacement with ,50K miles?
When did bodies/drive train change? good-better? Any advise on specific jEEP YEARS/EQUIPMENT/MARKETS TO SHOP?
I drive on highway 20%, off road20%, in deep snow 20%, pull M416 Jeep utility traiiel 20% and pull Airstream Safari Trailer 20%on and off road.
Need tow package, cooling package, NOT,, full tme four wheel drive
tHANKS
Fredthecat is offline
post #2 of 9 Old 07-24-2011, 11:27 PM
davigzj
In 99 the zj became the wj very nice had a2001 for a few months V8 4.something AWD because of v8 but with all that towing that might be best for u and awd is nice in snow. My. 02˘…
davigzj is offline
post #3 of 9 Old 07-24-2011, 11:47 PM
FlamingRain
To be honest - you're going to be lucky if you find a ZJ with 50k miles on it. Ours is at about 120.xxx now (5.2), and the engine runs like a champ. (minus a steering gear, the A/C does not work, and the parking brake does not work)
If you're looking for something good - get one with a 5.2 V8. Those engines, if you treat them right, are damn good engines. They've got lots of torque- particularly at low range. Ours in 4lo jumps forward just releasing the brake pedal on a flat surface. They also sound good when they go fast :P Although they're not quite as broken-in and tested as the 4.0 (which was a standard for many many years, unlike the 5.2 which was only available for 7-8.) I think it's worth the money. Also 5.9's are cool and I'm really looking into getting one.
2wd can really get you places you can't get out of without 4lo. - Ratmonkey
FlamingRain is offline
post #4 of 9 Old 07-25-2011, 12:26 AM
phitmein
phitmein's Avatar
If you are riding a good horse, then why try replacing it in mid-stream ???
Phit
phitmein is online now
post #5 of 9 Old 07-25-2011, 12:43 AM
Candymancan
and whats wrong with your current Jeep ? You arent gonna find a ZJ with 50k. 100k is being optimistic
Candymancan is offline
post #6 of 9 Old 07-25-2011, 05:25 AM
spur0701
I was thinking like you a few months ago. I've got a 98 ZJ 4.0 that I've had for about 12 years, I've got other DDs so only have 125K on it. It had a bunch of maintenance due (brakes, shocks, tires, and some other stuff) and I was thinking that it was old enough that I should start looking for a used WJ or whatever was the best bang for the buck.
But after researching I've changed my mind. I can expect to get at least another 100K out of the engine. I've never had any problems with it, parts are easy to find and maintance is pretty easy, plus the gas milage is decent for what it is (around 17-19 depending how hard I drive it).
So as long as you don't have anything major wrong with it I would drop whatever money you need to keep it ticking. If there's something major then I would look for a 98 Lorado, I personally think Limiteds have too many options that's just more things to go wrong.
spur0701 is offline
post #7 of 9 Old 07-25-2011, 01:32 PM
FlamingRain
Oh yeah, and I forgot to mention we've had that 5.2 ZJ for about 11 years now. (I'm 15... I practically grew up in it!)
post #8 of 9 Old 07-25-2011, 10:00 PM Thread Starter
Fredthecat
Thanks all. Didn't know ZJ begot WJ. Important info. Need to learn about Quada-Trac, AWD, V8s etc.
The laundry list for the 96 ZJ is growing too big….leaks and electrical.
Cracked exhaust manifold, rear pinion seal leaks, won’t pass smog (ECM sensors won’t reset after dead battery…..hundreds of miles & “Drive Cycles” later, door locks intermittent, distributer sensor died while towing, Phantom Battery Drain, Mini-Death Wobble at 48-50 MPH, A/C won’t hold charge…on and on.
No longer ultra reliable. Have ’86 CJ7 with 56K for Rubicon Runs (bought new), ’66 Volvo 122S and '67 BSA Thunderbolt for Daily Drivers.
Thanks for all the input.
Tried sister’s ‘04 Grand Cherokee on for size….that may do it.
Shopping,
Fredthecat
post #9 of 9 Old 07-25-2011, 10:10 PM
FlamingRain
Ah, you should have stated you had problems.
I still say go with v8s. That's what Grand Cherokees are for. :P
I've got a gnarly laundry list of problems I need to fix with mine (they're not engine related though :P)
Need Some Advise.... Budabear ZJ Grand Cherokee Forum 3 01-27-2011 06:55 PM
Please Advise robtre WK Grand Cherokee & XK Commander Forum 3 04-02-2009 10:42 AM
WJ Advise BlaineWasHere ZJ Grand Cherokee Forum 12 02-24-2006 03:01 PM
need advise simontor ZJ Grand Cherokee Forum 2 07-21-2005 10:02 AM
Carpet replacement advise sought zrexron ZJ Grand Cherokee Forum 4 08-04-2003 03:59 PM
