Replaced pinion seal. Now noisy. - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > Replaced pinion seal. Now noisy.
FS: Jeep Fog Light LED Bulbs! Several Brightness Options! Hey Guys - Extreme Terrain Jeep Outfitters - ExtremeTerraiThe Original 3/8" Ruffstuff Diff Cover!
Unread 04-19-2015, 06:29 PM   #1
CamoX413
hey everybody, I thought I would try to replace my rear pinion seal today on my Dana 35. I did plenty of research and thought I was up to the job. I marked everything before I took it apart. the socket rubbed the marking off the pinion nut. I was pretty sure I found a bit of the mark left so I used that to line it back up with the mark on the pinion. now I'm getting somewhat of a grinding sound on acceleration it stops at high speeds and i mostly notice it between 20 to 40 mph.
also I just had a custom cat back exhaust installed yesterday so I don't know if the noise is coming from that or the differential but I didn't notice the noise at all after doing the seal.
CamoX413 is offline   Reply With Quote Quick reply to this message
Unread 04-19-2015, 06:49 PM   #2
CamoX413
I meant to say that I didn't notice the noise until after I did the pinion seal. I just crawled under the jeep and noticed that my exhaust sits right against my gas tank skid and the rubber grommets on the hanger is worn. if I shake the exhaust it bangs against the skid.
Unread 04-20-2015, 06:54 AM   #3
CamoX413
does this sound like it could be something inside my diff?
Unread 04-20-2015, 06:56 AM   #4
CamoX413
It seems to be intermittent also. I notice it more when I'm really getting down on the throttle.
Unread 04-20-2015, 07:09 AM   #5
WiryOak
Wrap your exhaust where it hits with soaking wet bluejeans. Quickly test it on a backroad, If it still makes a noise then its not your exhaust.
WiryOak is offline   Reply With Quote Quick reply to this message
Unread 04-20-2015, 01:48 PM   #6
CamoX413
Had the exhaust shop rework the pipe this morning. Haven't heard anything yet but I just left the shop so I'll update later
Unread 04-20-2015, 03:06 PM   #7
Daing_Maing
I just replaced my rear pinion seal about three weeks ago. I did not tighten the pinion nut enough when I reinstalled it. I was getting a garbling metallic sound out of the differential at 35-50 mph when I accelerated. There are a couple of threads here on the forum that explain the noises that are made when you crush the spacer behind the nut, or under tighten/torque the nut as well.
My situation was in which I had not tightened it enough. I had one more full rotation on the nut + 5% to be sure the crushable spacer was engaged properly. I also did not do the replacement 'by the book' with taking off the tires and removing axle shafts, etc....
Good luck man...
Daing_Maing is online now   Reply With Quote Quick reply to this message
Unread 04-20-2015, 04:48 PM   #8
CamoX413
I did it the same as you. Just jacked her up and marked everything and took it apart.
It seems my new exhaust was the culprit in what I was hearing but the rear does still sounds somewhat noisy like drone.
