Replaced output shaft speed sensor - still CEL & still not shifting! - JeepForum.com
post #1 of 12 Old 05-22-2013, 01:47 PM Thread Starter
Vortexium
My mechanic just replaced my outspeed shaft speed sensor because that's what the code read, and it's still doing the same exact thing... any ideas or suggestions? I have a 98 ZJ with the 42RE and 133k. 5.2l motor..
Vortexium is offline
post #2 of 12 Old 05-22-2013, 02:12 PM
jeepkid945
Reset computer?
jeepkid945 is offline
post #3 of 12 Old 05-23-2013, 12:33 AM
jabba974
Have you looked at replacing the shift solinoids in the tranny? My 96 wouldnt down shift to first and would only start out in 2nd gear...Once in a while it would stick in first and would not up shift...Once replaced, it worked perfect..
jabba974 is offline
post #4 of 12 Old 05-23-2013, 06:33 AM
dusterdude
How long after is the lite still on,it may take a couple of days to turn off
dusterdude is offline
post #5 of 12 Old 05-23-2013, 03:13 PM Thread Starter
Vortexium
It's still doing the same thing after I replaced it. The tranny doesn't shift out of first, it takes like 10 seconds and I have to basically tac it to 3500
post #6 of 12 Old 05-23-2013, 11:09 PM
jnicewan
There is a code related to the sensor, the sensor has been replaced. There is probably one of two things wrong with it. Either the wrong sensor was replaced or the part is bad or it was not a sensor problem to begin with and might be a wiring or PCM problem.
Keep in mind that there is a VSS sensor on the T/C and the output shaft speed sensor is on the trans-O/D housing. I am sure they know which and replaced the correct sensor.
jnicewan is offline
post #7 of 12 Old 05-29-2013, 08:36 AM Thread Starter
Vortexium
Bump, need some more info !!
post #8 of 12 Old 05-30-2013, 04:50 AM
ZeeJay1997
this
ZeeJay1997 is offline
post #9 of 12 Old 05-30-2013, 05:04 PM
coralman
USER OF PARTS CATALOGS
coralman's Avatar
Lol, you would go in the ignore room if you completed that bottom sentence. You had to know that going in.
Originally Posted by HighLonesome
coralman is offline
post #10 of 12 Old 05-30-2013, 05:44 PM
ZeeJay1997
In typical RM fashion, that was the end of the conversation
post #11 of 12 Old 05-31-2013, 08:52 AM
KingtheZJ
i assume it threw a code for vss and speedo wasnt working?
is the speedo working now?
reset code or reset computer.
'88 XJ
'98 ZJ on 37s and tons
'02 Chevy 2500HD 8.1
KingtheZJ is offline
post #12 of 12 Old 09-19-2013, 05:10 PM
Nolvck
2010 JK Wrangler
Did you find a fix? My zj is doing the same thing. Replace both output and vss. Still getting code and symptoms
Nolvck is offline
