Replaced fuel filter now hard to start - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > Replaced fuel filter now hard to start
FS: Wranger BRIGHT License Plate LED! Just $3! Great valueROCKRIDGE4WD Introduces a NEW Jeep Wrangler JK *led* tail Premium LED Lighting by VISION X, Proudly sold at ROCKRIDG
Unread 06-14-2014, 08:47 PM   #1
Bchain5
So I replaced my old fuel filter with a new drive works fuel filter. I have double checked and ik that it is facing right direction. Jeep will start and run but takes really long turns 2-3x for it to start up?
Bchain5 is offline   Reply With Quote
Unread 06-14-2014, 09:13 PM   #2
jm8881
Check for a leak in any of the lines too and from the filter. The tiniest leak (even one that doesn't have a noticeable drip) will allow air into the lines and lower the fuel pressure and make it harder to start. Other than that I am not a fan of drive works anything.
jm8881 is offline   Reply With Quote
Unread 06-14-2014, 09:21 PM   #3
firsttimeZJ13
Did you by chance loosen the gas cap and forget to tighten it back? I may have done that before..
1995 ZJ, 5.2L, NP249, stock suspension, e-fan, CAI, engine needs work!! Plan on lift and tires when money finds its way here...
firsttimeZJ13 is online now   Reply With Quote
Unread 06-14-2014, 09:32 PM   #4
Bchain5
Alright I'll check that and has cap in the morning!
So I checked cap was definitely on. I made sure lines were snug on filter as they could be and seemed tight as possible, so after checking that it didn't take as long to crank but still was hard to start. Once I started it I couldn't feel any air hissing out.
