Replaced front axle/CV joint now a bad whining from front end? - JeepForum.com
post #1 of 5 Old 09-11-2004, 07:26 PM Thread Starter
f1rz06
I just replaced my passenger front CV joint/axle assembly after the bearing the in CV joint exploded. Now mostly on acceleration and during cruise there is a whining coming from the front end. It kind of sounds like when you set up a differential bad or something, but nothing was touched except for the CV joint. The install went smooth, nothing out of the ordinary. My friends first impression was that it seemed like it was "out of balance" from the opposite CV joint but I've never heard of having to mate CV joints at cetain points. The noise is purely speed and load dependant, when cruising as you hit bumps or get on and off the gas the noise gets better and worse.
Any help would be greatly appreciated. Oh, this is the full time 4wd version if that matters.
f1rz06 is offline
post #2 of 5 Old 09-11-2004, 11:12 PM
boredinocala
[maybe the axle nut was overtorqued at the wheel?? OR undertorqued - either way it can mess up the hub bearing....
boredinocala is offline
post #3 of 5 Old 09-12-2004, 09:11 AM Thread Starter
f1rz06
Any idea what the torque specs are for the axle nut?
f1rz06 is offline
post #4 of 5 Old 09-12-2004, 11:52 AM
greasefingers
greasefingers's Avatar
1994 ZJ
The torque specification is 175 Ft-Lbs for my 94ZJ. You can not really screw these things up if you under/over tighten them. The hub bearings are sealed non-serviceable part. Itís not like some cheap tapered roller bearing found on most 2WD vehicles.
Cheers Steve
94 Black Laredo 4-Liter with QuadraTrac (42RE trans & NP249 TC) 200,000 + miles purchased new
88 Cherokee 2-door with 5speed manual 139K miles(deceased) purchased new
greasefingers is offline
post #5 of 5 Old 09-16-2004, 02:48 AM
Colorado 5.9
Colorado 5.9's Avatar
It could be a BAD new CV joint too.
ZJ 98 5.9 LTD. Lots of mods. 7" T&T's Long Arm Lift ,BFG KM2"s,35X12.50x16's,4:56's, Vanco brake upgrade, M1intake,Holley52mmTB,MikeLeach Headers,, Arb'ed HP D30,Aussie Locked rear,Procomp MX6 Shocks,Arb front,RearTR bumpers,ECT.ECT.
Colorado 5.9 is offline
Front End noise after u joint replaced cyberZJ ZJ Grand Cherokee Forum 25 12-10-2009 01:44 AM
Front End noise after u joint replaced cyberZJ ZJ Grand Cherokee Forum 0 12-02-2009 05:04 PM
Front Axle: CV to U joint Casper4x4 ZJ Grand Cherokee Forum 4 07-22-2008 12:12 PM
2004 WJ Front Axle Whining Noise ArmyRanger ZJ Grand Cherokee Forum 0 01-07-2008 06:44 PM
Front Axle whining on the Highway Rhinehard ZJ Grand Cherokee Forum 2 08-09-2004 12:35 AM
