REplace with what torque converter? - JeepForum.com
post #1 of 9 Old 07-26-2011, 05:35 PM Thread Starter
Spike300
My trannies gone on my jeep, and im planning on picking up a used one with 67k on it this weekend for $350. What torque converter should i use? the one that come with the one im gonna pick up, my current one or a new one?
5.2-242 tcase-44a-30x9.50x15 MT/R-American Racing Burst Rims -Optima -E3 plugs-Custom Paint-Amsoil-Addco Front and Rear-polyurethane bushings
To be installed: RE gen2 discos, military battery terminals
To be rebuilt: HP30
To be received:
To be paid for:
Next on the list: complete redo of brakes and
lines
Needed: fittings, coil of brake tubing, Russel speed bleeders
Zombie Outbreak Response Unit #75
Spike300 is offline
post #2 of 9 Old 07-26-2011, 05:38 PM
JrMechanic
Either the one that comes with it or a new one, do not use your old one.
Want to swap an NP242 or NP231 into your ZJ? Here's how:
JrMechanic is offline
post #3 of 9 Old 07-26-2011, 05:44 PM Thread Starter
Spike300
What should i replace along with it right way? filter for sure, but are there any sensors that i should replace also? Or anything else?
To be rebuilt: HP30
To be received:
To be paid for:
lines
Spike300 is offline
post #4 of 9 Old 07-26-2011, 05:46 PM
Virmagicus
Virmagicus's Avatar
Crank sensor for sure! Do it while the tranz is pulled. About a 5 min job.
Jeff
Virmagicus is offline
post #5 of 9 Old 07-26-2011, 05:49 PM Thread Starter
Spike300
ok, any type of lines, fittings? Whats the best way o add fluid? I mean do you have to fill up the torque converter separatly or do you dump it all down the dipstick tube?
To be rebuilt: HP30
To be received:
To be paid for:
lines
Spike300 is offline
post #6 of 9 Old 07-26-2011, 06:21 PM
Virmagicus
Virmagicus's Avatar
The converter will take almost a quart. Good idea to fill it up first. Just make sure it gets seated all of the way before installing. If there is a gap when lining up the tranz do not suck the bell housing up tight with the bolts or force it flush. If the converter is seated properly it should line up and seat flush.
Jeff
post #7 of 9 Old 07-26-2011, 07:03 PM
leadfootny
Make sure to flush the lines and cooler. NAPA sells a product called Kooler Klean that works well. Also might be a good time to add a secondary cooler if you don't have one.
leadfootny is offline
post #8 of 9 Old 07-26-2011, 08:57 PM
General_Jeep
1994 ZJ
Just do a NV3500 swap =P save your self the trouble of a Auto trans dying again lol. just my 2 cents
1994 Jeep Grand Cherokee 5.2L V8- NV3500 - Blown D35 8.8 replacement some day.
2010 Jeep Patriot 5 speed manual-- DD, 27-31MPG :D
1996 Dodge Ram 1500 - Work Truck/Plow 5.2L NV3500
2005 Nissan Titan - Hauler
"The Jeep is Americas only real sports car!" - Enzo Ferrari
General_Jeep is offline
post #9 of 9 Old 07-27-2011, 05:04 PM Thread Starter
Spike300
thought bout a manual. but i like auto, easier if i ever need somebody to drive my jeep
To be rebuilt: HP30
To be received:
To be paid for:
lines
Spike300 is offline
Torque converter? classicmetalman ZJ Grand Cherokee Forum 1 04-17-2011 09:37 PM
can my torque converter be going bad? MuddSlutt ZJ Grand Cherokee Forum 5 11-25-2010 08:54 AM
replace 44re torque converter or do soft rebuild? cowteets ZJ Grand Cherokee Forum 0 10-05-2010 01:38 PM
Torque Converter rkoz1 WK Grand Cherokee & XK Commander Forum 1 04-30-2008 06:24 PM
Help with torque converter daytondb ZJ Grand Cherokee Forum 0 12-26-2007 01:11 PM
