Replace Serpentine Belt on '93 Grand Cherokee ?? - JeepForum.com
post #1 of 5 Old 05-17-2007, 09:29 PM Thread Starter
thomast
I've got a 1993 Grand Cherokee with the in-line six cylinder. I'm trying to remove the old serpentine belt and replace with a new one. I don't belive this engine has the automatic tensioners, so the belth has to be removed by taking loose the power steering pump. I've found the long tensioning bolt under the power steering, and backed it nearly all the way out after loosening the lock nut under the pump. I've loosened what I thought to be the pivot bolt on the top of the pump, but still can't get the pump to move to release the old belt. What exactly is the procedure for getting this danged thing off....??? Thanks in advance for any help!
thomast is offline
post #2 of 5 Old 05-17-2007, 09:36 PM
driabyor
driabyor's Avatar
1994 ZJ
there are 3 bolts.....2 that hold the pump , and one that adjusts the pump
94 Grand Cherokee ... 332,000 miles
5.2 liter 242 :)
Rancho 5000 steering stabilizer
driabyor is offline
post #3 of 5 Old 05-18-2007, 12:32 AM
stealthzj
stealthzj's Avatar
1994 ZJ
two words... Haynes Manual.
DrIvE iT LiKe A ReNtAL
don't go away mad...... just go away.
stealthzj is offline
post #4 of 5 Old 05-18-2007, 07:34 AM
2007GTCS
+1 to both posts above. There are 2 pivot bolts...I'm pretty sure you've already loosened the upper one...there's another one right underneath it. Also, get the Haynes manual...it's cheap and has step by step instructions with pictures on how to do this and a whole bunch of other things. Make sure you route the new belt properly!
2007GTCS is offline
post #5 of 5 Old 05-18-2007, 09:42 AM
greasefingers
greasefingers's Avatar
1994 ZJ
There are 4 bolts to loosen (2 in the front& 2 in the back) and then the additional long adjuster bolt will be able to move things.
Cheers Steve
94 Black Laredo 4-Liter with QuadraTrac (42RE trans & NP249 TC) 200,000 + miles purchased new
88 Cherokee 2-door with 5speed manual 139K miles(deceased) purchased new
greasefingers is offline
'93 grand cherokee serpentine belt broke and need an estimate on cost to fix slivver71 ZJ Grand Cherokee Forum 22 05-29-2016 12:17 PM
Serpentine belt 2000 Grand Cherokee 4.0 mbolena ZJ Grand Cherokee Forum 2 02-10-2010 05:09 AM
98 5.9 Grand Cherokee Serpentine Belt d1rtr1der ZJ Grand Cherokee Forum 0 08-20-2006 07:51 PM
1997 Grand Cherokee Serpentine Belt Adjustment Problem Den46 ZJ Grand Cherokee Forum 2 11-04-2005 09:35 PM
99 Grand Cherokee Loreado serpentine belt dieseldogpi ZJ Grand Cherokee Forum 5 05-14-2005 06:35 PM
