Replace factory radio w/ after market...Worked, when went to put electical tape, noth - JeepForum.com
post #1 of 26 Old 12-26-2009, 01:29 PM Thread Starter
KillaKam79
I just replace my factory radio w/ an aftermarket (Alpine CD/Radio). I took out the factory unit and install the Alpine radio, wired everything together w/ the wiring kit. Test the new radio, works fine. Now I need to put electrical tape, taped everything together and now the radio doesn't work, no power no nothing. Checked all the wires and everything looks fine, I even took all the wires apart and put it back together just to make sure that all the wires were put together correctly. Now I'm like "F***" I blew the radio. So I decided to put the factory unit back on and same problems, no power no nothing. Checked all the fuses and there was no blown fuse. So what now??? Did I loosen a connection somewhere??? Any help would be great...Thanks!!!
KillaKam79 is offline
post #2 of 26 Old 12-26-2009, 01:49 PM
cmonson
do you have 12V at the power connection?
cmonson is offline
post #3 of 26 Old 12-26-2009, 02:05 PM Thread Starter
KillaKam79
yeah its all connected
post #4 of 26 Old 12-26-2009, 02:11 PM
MAUSS
Ok, it's connected... but is there 12V there?
Tell me you weren't just twisting the wires together and wrapping them with electrical tape.... please.
'93 Limited (sold), '96 Laredo
MAUSS is offline
post #5 of 26 Old 12-26-2009, 02:46 PM
cmonson
I second that...
You should be using wire nuts or crimp on connectors with shrink wrap.
did you verify 12V yet?
cmonson is offline
post #6 of 26 Old 12-26-2009, 03:34 PM Thread Starter
KillaKam79
The 12 volt wires are connected and it still does not come on. Even when I connected the factory radio and that doesn't work either. I got the aftermarket wiring harness. Like I said it worked before when I was connecting it earlier, but when I was taping everything off, that's when it didn't work anymore. Can I just connect the the 12 volt wire directly to the battery? Do I only connect it to the + terminal?
post #7 of 26 Old 12-26-2009, 03:59 PM
cmonson
again, for the 3rd time, did you verify with a volt meter that you have 12V at the wire???????????????
cmonson is offline
post #8 of 26 Old 12-26-2009, 04:03 PM
impuresoul2k3
Originally Posted by cmonson View Post
I second that...
Or even better, solder the wires and cover with heatshrink tubing
1993 Grand Cherokee Limited, 5.2L
Modified/Slightly Ported Kegger
Air hat spacer
Modified Throttle body
Flowmaster muffler
impuresoul2k3 is offline
post #9 of 26 Old 12-26-2009, 04:11 PM Thread Starter
KillaKam79
I don't have a 12 volt meter to verify it, should I go to autozone to see if they can test that for me?
post #10 of 26 Old 12-26-2009, 04:13 PM
cmonson
No, go to autozone so that you can buy one. In all truth, this is an essential tool and you will get years of use out of it.
cmonson is offline
post #11 of 26 Old 12-26-2009, 05:17 PM Thread Starter
KillaKam79
I went to autozone and bought a 12 volt tester, I tested the wires and NO I'm not getting any current from the 12 volt wire. So what can I do??? I got currrent from ignition and the illumination wire but not from the constant 12 volt wire. cmonson, thaks for being patient with me, you have been a great help. But what should I do now???
post #12 of 26 Old 12-26-2009, 05:46 PM
WJChris
WJChris's Avatar
You are meassuring VOLTS with a voltmeter. Measuring current is different.
What should you do now? Follow the schematics and locate the spot where the 12v stops.
I suggest you check the fuses again, all of them.
I have an FSM and access to schematics if I can be of help.
WJChris is offline
post #13 of 26 Old 12-26-2009, 05:55 PM
WJChris
WJChris's Avatar
you have 2 fuses. A RED/WHT wire that runs from the POWER DISTRIBUTION CENTER (FUSE 15, 50A) (that supplies the radio, amplifier, front power outlets and rear outlet). There is a fuse (FUSE 5, 25A) in the junction block.
Check the junction block first. Its located lower left, below the steering wheel and above the dead pedal under the dash. If the power outlets also do not work, the problem is with the supply at the PDC. The PDC is located in the engine compartment, passenger side between the battery and the fender.
There also is the RUN-ACC switched line (RED/WHT) that has (FUSE 30, 15A) from the junction block. That supplies voltage only when the key is in the correct position.
WJChris is offline
post #14 of 26 Old 12-26-2009, 06:03 PM Thread Starter
KillaKam79
Originally Posted by WJChris View Post
do you have the infinity system?
No, the base model, even the factory radio doesn't work when I put it back in. I did not splice any factory wires, I bought a wire harness kit. I check all the fuses under the driver side and in the engine and everything looks fine. What could it be???
post #15 of 26 Old 12-26-2009, 06:22 PM
WJChris
WJChris's Avatar
re check my post, I edited it....
WJChris is offline
i am gonna replace the factory stereo. HELP!! ronsaun ZJ Grand Cherokee Forum 2 12-27-2009 10:06 AM
Need to replace factory head unit? Zj1994 ZJ Grand Cherokee Forum 3 12-07-2009 04:05 PM
Sub with a factory radio Arcticcat843 ZJ Grand Cherokee Forum 15 11-22-2009 06:02 PM
after market radio install jrskblx125 ZJ Grand Cherokee Forum 0 02-16-2004 09:50 AM
Can you replace stock radio and not lose the sterring wheel controls? JuIcE_2000WJ WJ Grand Cherokee Forum 7 06-19-2003 06:41 AM
