Replace Cooling fan module - JeepForum.com
post #1 of 4 Old 09-29-2009, 10:31 PM Thread Starter
tpleiman
Can anyone provide a link or post on how to replace the cooling fan module in a 2002 Jeep Grand Cherokee V6? My fan continued to run even after car was off. I replaced the relay and everything seemed good for a week or so. Now again my fan will not shut off. I assume the relay is bad again.
After some research, sounds like I should try replaceing my cooling fan module. I read that my current fan may be drawing too many amps causing the relays to go bad?? Any thoughts??
I want to attemt to replace myself if you think this is my next best option??
Thanks, if possible please provide a link or post on how to replace fan.
tpleiman is offline
post #2 of 4 Old 09-30-2009, 07:30 AM
mikes3860
The fan is running because something is tell it to. The relay maybe stuck but it's not likely. If you think it's the relay try swapping it with another one in the power distribution center. From what I have seen in the past it is the TIPM.
mikes3860 is offline
post #3 of 4 Old 09-30-2009, 10:42 AM
the88thpianoman
2003 WJ
The WJ has a special fan relay located under the passenger headlight, it is not one of the relays in the power distrib center.
2003 WJ in Jeep Green Metallic, 4.0/242/4.10's. 4" Teraflex springs w/ RE monotube shocks and IRO short arms, cheap intake w/ amsoil filter, 2.5" hi flow cat and back exhaust, lots of lights and other misc crap.
Check out my build thread here:
the88thpianoman is offline
post #4 of 4 Old 10-01-2009, 12:41 AM
sprocket1200
fan relay is super easy to replace. search and just follow the directions about drilling the hole under the headlight.
the relays from caravans and grand caravans work. i just went to junk yard and got them super cheap.
sprocket1200 is offline
How to replace transmission cooling hoses 1997 Grand Cherokee? jlconlin ZJ Grand Cherokee Forum 13 04-05-2014 04:10 PM
Body Contorl Module or Door Control Module?? Drdan524 ZJ Grand Cherokee Forum 4 05-19-2010 02:04 PM
Have to replace AC evap what else should I replace? crashcraddock ZJ Grand Cherokee Forum 17 06-28-2009 07:55 AM
Wired up blower motor power module - do I need to replace blower motor? sniperdude ZJ Grand Cherokee Forum 0 04-19-2009 03:33 PM
Driver Door Module or Body Control Module ronmaynard ZJ Grand Cherokee Forum 3 04-28-2008 09:13 AM
