Replace Control Arm Bushings with outer sleeve? - JeepForum.com
post #1 of 15 Old 06-15-2009, 02:41 PM Thread Starter
gmartin1215
I am going to replace the front control arm bushings (upper and Lower) on my 98 ZJ. The bushings I have are the Clevite (I think) and are complete withe the outer metal skin.
Obviously, these are pressed int to control arms. So, has anyone replaced these using a method that does not involve a shop press? I can see that one way to remove the old bushings is to cut, or burn, the rubber out and then crimp the old sleeve to slide it out. But what are other methods of installing the new ones with that already have thier outer skin on?
On the upper control arm bushings that are on the axel, how are these removed completely and reinstalled? Can a tool be rented to to do this??what would work??
gmartin1215 is offline
post #2 of 15 Old 06-15-2009, 02:44 PM
Greengc4x4
This
Greengc4x4 is offline
post #3 of 15 Old 06-15-2009, 02:44 PM
Greengc4x4
Or you could buy my control arms that are forsale
post #4 of 15 Old 06-15-2009, 02:54 PM Thread Starter
gmartin1215
Thanks. But I already have the bushings.
Did you replace the bushings on your control arms that are for sale yourself?
If so what did you do to install the new ones? How did you do the axel bushings?
post #5 of 15 Old 06-15-2009, 02:55 PM
Greengc4x4
no I didnt do them. They were replaced by the guy I bought it from right before I bought it. ive always heard of people burnung them out. Thats what I would do.
post #6 of 15 Old 06-15-2009, 03:23 PM
rugermack
I burn them to get out the center sleeve, then use a sawsall to cut the outer tin shell, then they fall out. Still time consuming.
95' Jeep Grand Cherokee Laredo, 148k, 5.2, NP242, 46RH, 4" RC lift, all new adjustable ca's(2 IRO front uppers and the rest RC adjustables), nitro shocks, JKS TB's, Jet Chip, Dynamax cat back, Magnaflow cat, GTP hood vents. 31" Pro Comps with Rock Krawler "D"s. Westin brush/grill guard with Hella 500s, 411's, Solid diff covers, detroit locker rear, power lock in front, SYE and Tom Wood's front/rear shafts, RE discos, BPE's, d-rings front and back, factory tc and rad skid, hitch, Sliders next.
03' Jeep Grand Cherokee Laredo, (wifes Jeep) 99k, 4.7 5 speed auto, K&N, KYB shocks, drilled-slotted rotors, All the toys.
2000' Ford Superduty, F250, 7.3, 198K, 37's, too much to list.
Built Not Bought #257
Parts for sale d30 and d35 parts
rugermack is offline
post #7 of 15 Old 06-15-2009, 05:32 PM
muddyjgc
2005 WK
You can rent a Ball Joint Press from a Autozone or other auto parts store. It is really just a huge C clamp with various adapter rings, and by using those rings and some other Large sockets and peices of scrap metal that you might have laying around you can use it to press the old joints out and press the old ones in. Just be careful not to crush the two sides of the control arm together as you are pressin the new ones in.
This is what I did to replace my bushings that had 190,000 mi on them and I think it was much easier than burning and cutting them out.
muddyjgc is offline
post #8 of 15 Old 06-15-2009, 06:04 PM
Bort62
Don't burn them out. It's ghetto and takes way too long.
Use an air chisel. Put a pointed tip on it and puncture the bushing sleeve.
Then push the bushing out w/ the chisel hammering away. I just did mine yesterday and I popped the UCA bushings in the front axle out in like 30 seconds this way.
Press them in w/ a ball joint press - free rental from Autozone.
___________
'98 Grand
'60 Ranchero
Bort62 is offline
post #9 of 15 Old 06-16-2009, 12:16 PM Thread Starter
gmartin1215
Thanks all!
What about removal/install of the bushings on the arms (LCA and UCA)? Same kind of methods and using a ball joint press??
post #10 of 15 Old 06-16-2009, 02:56 PM
Bort62
Originally Posted by gmartin1215 View Post
Thanks all!
Yes.
You can press them out as well, but the chisel is faster.
___________
'98 Grand
'60 Ranchero
Bort62 is offline
post #11 of 15 Old 06-16-2009, 03:08 PM Thread Starter
gmartin1215
Thanks!
I don't have an air chisel. SO I guess I will have to use the ball joint press
post #12 of 15 Old 06-16-2009, 03:47 PM
newfieZJ
And , if your really stuck for tools , no clamps , no press , a simple carpenters hammer will also do the job quite easily . I replaced 14 out of the 16 bushings like that excluding the frt axle bushings when I had stock arms , works well and fast too , probably not the best way though , the press is better
1995 Orvis build
1988 MJ build
1998 Slate 5.9 build
1998 Platinum 5.9 build
newfieZJ is offline
post #13 of 15 Old 06-16-2009, 08:54 PM
muddyjgc
2005 WK
I forgot, I did use an air chisel to help knock out the drivers side UCA. And a 2-3 lb hammer and a large socket to R and R the bushings in the arms. I used the ball joint press mainly on the bushings on the axle mounts since there was not much room to work.
muddyjgc is offline
post #14 of 15 Old 06-17-2009, 12:15 PM Thread Starter
gmartin1215
Sorry, R and R the bushings in the arm?? What is R and R?
post #15 of 15 Old 06-17-2009, 05:34 PM
muddyjgc
2005 WK
Remove and Replace
muddyjgc is offline
Replace front control arm bushings gmartin1215 ZJ Grand Cherokee Forum 3 05-01-2009 05:20 PM
anyone replace their A-arm balljoint and bushings? lakailimited06 ZJ Grand Cherokee Forum 5 04-15-2009 07:47 PM
Replace Bushings How To? gmartin1215 ZJ Grand Cherokee Forum 1 04-15-2009 03:22 PM
My Control Arm Bushings Are Bad! Anyone replace their own in a WJ? Soft 8 ZJ Grand Cherokee Forum 13 07-17-2008 09:34 PM
How to replace sway bar bushings? Germerican ZJ Grand Cherokee Forum 13 12-28-2007 10:48 PM
