Repairing headlight switch that causes dimming issues *picture heavy* - Page 4 - JeepForum.com
post #46 of 162 Old 03-26-2012, 01:14 PM
congerz83
Just finished mine... worked like a charm. I would add a little bit of solder to each point instead of just "re-heating" them. If you can handle an iron carefully, do it.
congerz83 is offline
post #47 of 162 Old 03-26-2012, 01:51 PM
Howieb92
That's what I had to do. With mine I just added to the back side I didn't do any with the front by that little box.
Howieb92 is offline
post #48 of 162 Old 03-27-2012, 09:33 AM
congerz83
Why didn't you add any there? I don't know the technical specs, but that seems like a very, if not the most important part of the switch.
post #49 of 162 Old 03-27-2012, 01:38 PM
newfieZJ
Thanks to the OP , nice write-up . I need this done on the 5.9 , drives me insane when I do get a chance to steal it from the wife . I also know just the person for the job . He's visiting this weekend . It will be on the bench waiting for him
newfieZJ is offline
post #50 of 162 Old 04-01-2012, 08:46 PM
billfish16
Thx Sniperdude!!
I never soldered anything before, but I think I fixed the issue with my dashboard lights flickering on and off by following the instructions on this thread. Time will tell as this was an intermittent problem and I have not been using the Auto headlight mode. I did break the plastic dimmer button in two pieces but I was able to glue it back together.
billfish16
billfish16 is offline
post #51 of 162 Old 04-09-2012, 01:42 PM Thread Starter
sniperdude
If you have the problem with the VIC saying coolant sensor is bad, or random things that don't make sense, this same principle of repair applies to that as well.
You just need to take it out and resolder all the joints.
sniperdude is offline
post #52 of 162 Old 04-22-2012, 07:50 PM
MrRoundel
Thanks for the write-up
Thanks for putting the illustrated write-up on the site for people to use. It's a fine gesture. I finally got around to doing the job after waiting to get set of trim tools in order to remove the bezels, etc., before making the repair. I got a set of nylon tools from the Chinese Connection...er...Harbor Freight, for around $10.00. They worked. Definitely removing the trim was the biggest hassle, but next time it'll be easier. Everything seems to be working fine after dealing with the intermittent flashing dash for the last two years. Thanks again.
MrRoundel is offline
post #53 of 162 Old 05-04-2012, 07:59 AM
billfish16
Originally Posted by billfish16 View Post
Thx Sniperdude!!
billfish16
Update. Over 1 month later, no flickering of interior lights. Thx again for posting this fix!
post #54 of 162 Old 05-04-2012, 11:17 AM
ZJMTL
I just have to chime in that I did this and it completely fixed the issue. Thank you so much OP!!!
ZJMTL is offline
post #55 of 162 Old 05-04-2012, 11:22 AM
Oldfrog
2007 WK
Great write up. I just did mine and noticed another issue. The sliding dimmer switch is made with a 2 piece metal housing. The tabs that are bent down to hold it together werent all bent down properly. Evidently it caused the slider not to make good contact ( internally) at times. I bent them down with a pair of needlenose pliers and all the issues of dimming dash lights went away. I did, however find what looked to be a cold solder joint on one of the boards too.
2007 5.7 Hemi, Ltd. QD II -
1997 ZJ, 4,0 select trac, Up country, track lok.
Oldfrog is offline
post #56 of 162 Old 05-04-2012, 02:00 PM
YJInterceptor
Well hot dog. I was going to go pull a switch from a junk yard. I'll try this now. Thanks!
YJInterceptor is offline
post #57 of 162 Old 05-10-2012, 04:15 AM
YJInterceptor
Did it the other day and works perfectly. Thanks!
post #58 of 162 Old 05-10-2012, 05:49 AM
Snowfan2
I did it too. Works great. Thanks.
Snowfan2 is offline
post #59 of 162 Old 06-03-2012, 09:01 AM
_AdriaN_
I did this 2-14-10 and mine is still working just like it is supposed to. Just so you know it isn't a quick fix, it lasts long term.
96 ZJ 4.0
04 TJ 4.0
87 Rx7 TII
_AdriaN_ is offline
post #60 of 162 Old 06-03-2012, 10:18 AM
Snowfan2
What a great fix. Anyone know if it works the same for an on again off again sunroof switch?
Snowfan2 is offline
Headlight issues in my ZJ Flyinbrick ZJ Grand Cherokee Forum 4 02-04-2009 11:24 AM
Headlight question / picture request Kota04SXT ZJ Grand Cherokee Forum 21 08-07-2008 07:48 PM
07 CRD w/ Heavy Bullbar - Suspension Issues? basthen WK Grand Cherokee & XK Commander Forum 15 07-22-2008 06:28 PM
KOR/Kolak H4 Headlight Upgrade *Pic Heavy* KingPrat ZJ Grand Cherokee Forum 11 12-12-2006 09:19 PM
Jason's Sliders - Picture heavy njrealtor55 ZJ Grand Cherokee Forum 23 09-30-2005 03:10 PM
