Repairing headlight switch that causes dimming issues *picture heavy* - Page 2 - JeepForum.com
post #16 of 162 Old 11-07-2010, 02:14 PM
ExpeditionXJ
Originally Posted by timmay5309 View Post
I wish I would have seen this thread before replacing the switch. Great write up!
X2 I just today swapped in a new switch assembly thats doing the same thing, so i'll get to do this method as well.
But now i also have the fog light switch.
ExpeditionXJ is offline
post #17 of 162 Old 11-07-2010, 05:04 PM
Tudds
This fixes the auto headlights flashing or just the dimmer bouncing around making them flash?
Tudds is offline
post #18 of 162 Old 11-19-2010, 12:57 PM
redbullrr
1987 YJ Wrangler
Cool, just did this cant wait to see if it worked when I put it back in. Seriously everyone one of those points from the 1 board to the other were cracked. It was just wobbling.
redbullrr is offline
post #19 of 162 Old 11-21-2010, 11:36 AM
Tudds
Finally swapped in my fixed switch. It works!!! I'll put my extra one on ebay unless someone on here wants it
Tudds is offline
post #20 of 162 Old 11-21-2010, 09:49 PM
minimodes89
minimodes89's Avatar
2017 JK Wrangler
done, now just waiting till its dark to make sure everything is good.
98 Jeep Grand Cherokee Limited-Stock 121000 On the clock-Sold
Penn State Alum:Industrial Engineering
Last edited by minimodes89; 11-22-2010 at 11:56 AM. Reason: opened my other light switch and figured out the answer
minimodes89 is offline
post #21 of 162 Old 04-16-2011, 07:57 PM
zjay
Awesome! Just picked this 96 up yesterday, this got the no dash lights problem fixed. Only needed to remove the white cover on the back of the switch. A magnifying glass lets you see the connections very well, they go from looking fine to looking bad. I had to follow a similar soldering write-up on my other 96 ZJ to get the low coolant warning off! Thanks--!!!
96 GC Limited V8 245,000 miles Scrapped
04 GC Limited 4.0 264,000 miles
96 GC 4.0 175,000
zjay is offline
post #22 of 162 Old 08-07-2011, 10:46 AM
almonet
can tell you how much time/money/aggravation you just saved me. thanks.
almonet is offline
post #23 of 162 Old 08-08-2011, 12:05 AM
Jeep98_zj
This works like a champ!!!
Great writeup! ... Too bad it wasn't around for my repair...
Also had to resodder the sunroof relay box and the VIC-info computer (to get rid of the low coolant warning)!!!
Jeep98_zj is offline
post #24 of 162 Old 10-13-2011, 02:32 PM
mangle
Very simple, fixed my problem. I always thought it was the pot itself going bad. To get the thing out of the dash, you have to undo a few of the screws on the knee blocker panel to pull it down and get at the third screw on the bottom of the headlight switch.
mangle is offline
post #25 of 162 Old 10-13-2011, 06:59 PM
98gcjeep
I've never soldered a circuit board but this was pretty simple. Thanks.
98gcjeep is offline
post #26 of 162 Old 10-23-2011, 04:03 PM
Beerfarm
Resolder worked!
SNIPERDUDE ! Great detail instructions. Removed my light control panel and upon examining the green circuit board & solder connections that connect the black female connector socket (the one that connects to the wiring harness), I noticed all the solder joints were dull gray. With a 10x hand magnifier I could see that the pins of the black connector were wiggling within the solder joints. I touched each of the connector's solder joints on the green circuit board with appropriate small soldering iron and solder. Once completed the green PC board was rigidly held to the black connector.
I did not touch any of the components solder joints on the green PC board as all those solder joints were fine. Only the solder joints of the black connector's pins. These pins/solder joints are the ones in a line next to the black connector.
Tested the repair last eve and IT WORKS PERFECTLY ! A tip of the hat to you !
Beerfarm is offline
post #27 of 162 Old 10-23-2011, 04:42 PM
phatgemi
I also completed this "fix" and am happy to report success. Thanks so much. Now if I could solve the cruise issue, I would be a happy camper.
phatgemi is offline
post #28 of 162 Old 10-23-2011, 05:17 PM
joeyb629
I did the same thing the other day. mine was flickering like crazy, driving me nuts. I bid on a used one on ebay but decided to see if i could fix it myself, it works great after fixing 4 cracked solders. Was hoping someone would outbid me on my ebay one but no luck, now i have another one on the way for 15 bucks...
joeyb629 is offline
post #29 of 162 Old 01-17-2012, 10:30 AM
jmonty0523
Just did this yesterday with my $20 jy switch. worked great! I'd definitely say $20 switch and now having auto headlights and factory fogs was a steal...
...________oooo_
/ ./.\...,\_____ \,_____
[_---_______---_\-\\\\\\-\
(o) )-o---) ) (o) )-o---) )______
jmonty0523 is offline
post #30 of 162 Old 01-23-2012, 03:58 PM
97jeepbeast
fixed last night so now I can stop beating the crap out of the switch to get the lights to work. thanks for the info sniperdude
97jeepbeast is offline
Headlight issues in my ZJ Flyinbrick ZJ Grand Cherokee Forum 4 02-04-2009 11:24 AM
Headlight question / picture request Kota04SXT ZJ Grand Cherokee Forum 21 08-07-2008 07:48 PM
07 CRD w/ Heavy Bullbar - Suspension Issues? basthen WK Grand Cherokee & XK Commander Forum 15 07-22-2008 06:28 PM
KOR/Kolak H4 Headlight Upgrade *Pic Heavy* KingPrat ZJ Grand Cherokee Forum 11 12-12-2006 09:19 PM
Jason's Sliders - Picture heavy njrealtor55 ZJ Grand Cherokee Forum 23 09-30-2005 03:10 PM
