Quantcast Repairing headlight switch that causes dimming issues *picture heavy* - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > Repairing headlight switch that causes dimming issues *picture heavy*
Truck-Lite's New LED Headlamp Series4.25" 97-06 Jeep TJ Wrangler Lift Kit - NO SYE NeededRuffstuff Axle Simple Swap Kit!
Old 02-24-2009, 11:41 AM   #1
sniperdude
If your jeep's lighted cluster/vic/hvac controls are dimming by themselves, it's probably due to bad solder joints on the headlight switch. I fixed mine yesterday and took some pics and added in instructions. This was done on a 97 Limited with auto headlights and fogs.
Tools:
  1. soldering iron that goes to 600-800 degrees farenheit.
  2. roll of Rosin Core Solder
  3. phillips screwdriver
  4. micro screwdriver
  5. Q-tips/swabs
  6. isopropyl alcohol
Enjoy.
sniperdude is offline   Reply With Quote
Old 02-24-2009, 11:46 AM   #2
gatorayde
fyi, a radio shack 15/30w soldering iron for ~$7 is your best bet for this. Cheap, and a good overall iron. 15w for the small electronics and 30w for the bigger ones (like ^).
gatorayde is offline   Reply With Quote
Old 02-24-2009, 11:47 AM   #3
sniperdude
Originally Posted by xJoshxx View Post
No clicky your welcome
Thanks, I was wondering what was up with that.
Old 02-24-2009, 11:49 AM   #4
gatorayde
You need to be a member for I think 30 days and/or have 50 posts to post images. Or you can buy a membership and be able to to it regardless of how long you've been here or posts.
Old 07-22-2009, 12:37 PM   #5
dhammer303
SNIPERDUDE! I just did this, and first of you instructions were spot on, AND it worked like a charm. In your other thread you spoke about "bending" where the two pieces meet. I had no idea what you were talking about until I disassembled my switch and sure enough, there was a lot of "bending". Once I resoldered the points there was no more "bending", and sure enough it works like new. This solved my problems with the Auto Headlights and the lights on my guages flickering. Thanks for the help!
dhammer303 is offline   Reply With Quote
Old 07-22-2009, 01:39 PM   #6
SnowLeopard
If only I had had this back when I needed a new headlight switch. I just got a replacement. I'm sure this will help a lot of people though. Thanks for sharing.
Yes, it snows in Texas.
SnowLeopard is offline   Reply With Quote
Old 01-20-2010, 06:28 AM   #7
daphne
Thanks for this great post, Sniperdude. I'd have just thrown out my part without doing the repair that you recommend. And it worked perfectly. To your excellent advice, I would just add one item for those with soldering experience. When "resoldering," you should always reheat with new solder. This helps fluxing and also acts as a bit of a heat sink.
daphne is offline   Reply With Quote
Old 01-27-2010, 12:16 AM   #8
chromedisguise
Sorry to bump an old thread... but thanks for this. I had to subscribe so I can find this later. Thank you for posting this! I thought I was the only one with this problem.
'98 Grand Cherokee 5.9
chromedisguise is offline   Reply With Quote
Old 01-27-2010, 07:51 AM   #9
sdowney717
if your dash lights are flickering up and down, you can clean the sliding contact switch with PB Blaster. it is a great electrical connection cleaner.
You got to spray it into the slider past the plastic dust flap and work the slider back and forth.
For some reason, my GC 1998 has numerous little electrical connection failures. Switches, sockets, wiring plugs stop working due to all i can guess high resistance corrosion. It is not visible when you look at the metal, but it is there.
for example radio connection plugs in back of radio, abs connection plug for rear wheel sensors under the dash, dash lamp sockets, headlamp switch, turn signal bulbs.
sdowney717 is offline   Reply With Quote
Old 01-27-2010, 08:22 AM   #10
baxy
dumb question why do we need to remove board to resolder the points the pics show all the points are accessable with the white cover removed ?
baxy is offline   Reply With Quote
Old 01-27-2010, 12:15 PM   #11
4Slow9erHybrid
No need to! I was just about to mention this. Just unscrew the white plastic cover and resolder. That's how I fixed mine.
If this alone doesn't fix it, then go ahead and take it apart. But getting the fog light switch plastic piece off is impossible on most of these without breaking something.
1997 JGC Laredo 4.0 4x4 94000mi * 0W30 German Castrol since 75k * 225/75/R15 Firestone Destination AT on Ravine rims * winter 235/75/R15 Bridgestone Blizzak DM-V1 * UC suspension * Monroe Reflex Monotube shocks * factory skids * KOR steering brace * rear Addco SB * Magnaflow cat and cat back system * complete 5.9 interior
4Slow9erHybrid is offline   Reply With Quote
Old 02-14-2010, 09:34 PM   #12
_AdriaN_
Tried this out today...
I just re-soldered up the back of the board, after you remove the white plastic and it fixed my problem.
THANK YOU VERY MUCH
96 ZJ 4.0
04 TJ 4.0
_AdriaN_ is offline   Reply With Quote
Old 09-29-2010, 08:09 PM   #13
Bigwidge
Just did mine! All the instructions were great, I had some trouble getting the panel out, but that was just me. Anyway, its all fixed now, thanks for the pictures!
The Silver Bullet- 96 ZJ w/ 31" BFG's on Pro-Comp Rock Crawler wheels, 4 KC Daylighters on roof (2 driving, 2 long range), Custom Front Tube Bumper (Made by JFCIII), 3.5" RE Kit with all of the goodies. JKS Trackbar, Bilstein Shocks, Rancho Steering Stabilizer, Control Arms
Bigwidge is offline   Reply With Quote
Old 09-29-2010, 08:27 PM   #14
timmay5309
timmay5309's Avatar
I wish I would have seen this thread before replacing the switch. Great write up!
timmay5309 is online now   Reply With Quote
Old 11-07-2010, 02:56 PM   #15
danvdd
Just fixed mine. It took over 6 months to get to it but it went off without a hitch.
danvdd is offline   Reply With Quote
Glock Forum
