-   -   Repairing headlight switch that causes dimming issues *picture heavy* (http://www.jeepforum.com/forum/f13/repairing-headlight-switch-causes-dimming-issues-picture-heavy-702703/)
sniperdude 02-24-2009 10:41 AM
10 Attachment(s)
If your Jeep's lit cluster/VIC/HVAC controls are dimming by themselves, it's probably due to bad solder joints on the headlight switch. I fixed mine yesterday and took some pics and added in instructions. This was done on a 97 Limited with auto headlights and fogs.
This seems to have become quite a popular thread. Glad it's still helping people out! - Edited 10/27/2015
Big shoutout to: Cerbere for re-uploading these images after Imageshack made off with them.
Tools:
  1. Soldering Iron
  2. Roll of Rosin Core Solder
  3. Phillips screwdriver
  4. Micro screwdriver
  5. Q-tips/swabs
  6. Isopropyl Alcohol
As an addendum (10/2015), I'd recommend also picking up some flux paste as it can make the adhering of the solder to the joints a hell of a lot easier.
Enjoy.
gatorayde 02-24-2009 10:46 AM
fyi, a radio shack 15/30w soldering iron for ~$7 is your best bet for this. Cheap, and a good overall iron. 15w for the small electronics and 30w for the bigger ones (like ^).
sniperdude 02-24-2009 10:47 AM
Originally Posted by xJoshxx (Post 6653823)
No clicky your welcome
Thanks, I was wondering what was up with that. :cheers2:
gatorayde 02-24-2009 10:49 AM
You need to be a member for I think 30 days and/or have 50 posts to post images. Or you can buy a membership and be able to to it regardless of how long you've been here or posts.
dhammer303 07-22-2009 11:37 AM
SNIPERDUDE! I just did this, and first of you instructions were spot on, AND it worked like a charm. In your other thread you spoke about "bending" where the two pieces meet. I had no idea what you were talking about until I disassembled my switch and sure enough, there was a lot of "bending". Once I resoldered the points there was no more "bending", and sure enough it works like new. This solved my problems with the Auto Headlights and the lights on my guages flickering. Thanks for the help!
SnowLeopard 07-22-2009 12:39 PM
If only I had had this back when I needed a new headlight switch. I just got a replacement. I'm sure this will help a lot of people though. Thanks for sharing.
daphne 01-20-2010 05:28 AM
Thanks for this great post, Sniperdude. I'd have just thrown out my part without doing the repair that you recommend. And it worked perfectly. To your excellent advice, I would just add one item for those with soldering experience. When "resoldering," you should always reheat with new solder. This helps fluxing and also acts as a bit of a heat sink.
chromedisguise 01-26-2010 11:16 PM
Sorry to bump an old thread... but thanks for this. I had to subscribe so I can find this later. Thank you for posting this! I thought I was the only one with this problem.
sdowney717 01-27-2010 06:51 AM
if your dash lights are flickering up and down, you can clean the sliding contact switch with PB Blaster. it is a great electrical connection cleaner.
You got to spray it into the slider past the plastic dust flap and work the slider back and forth.
For some reason, my GC 1998 has numerous little electrical connection failures. Switches, sockets, wiring plugs stop working due to all i can guess high resistance corrosion. It is not visible when you look at the metal, but it is there.
for example radio connection plugs in back of radio, abs connection plug for rear wheel sensors under the dash, dash lamp sockets, headlamp switch, turn signal bulbs.
baxy 01-27-2010 07:22 AM
dumb question why do we need to remove board to resolder the points the pics show all the points are accessable with the white cover removed ?
4Slow9erHybrid 01-27-2010 11:15 AM
No need to! I was just about to mention this. Just unscrew the white plastic cover and resolder. That's how I fixed mine.
If this alone doesn't fix it, then go ahead and take it apart. But getting the fog light switch plastic piece off is impossible on most of these without breaking something.
_AdriaN_ 02-14-2010 08:34 PM
Tried this out today...
I just re-soldered up the back of the board, after you remove the white plastic and it fixed my problem.
THANK YOU VERY MUCH:tea::cheers:
Bigwidge 09-29-2010 07:09 PM
Just did mine! All the instructions were great, I had some trouble getting the panel out, but that was just me. Anyway, its all fixed now, thanks for the pictures!
timmay5309 09-29-2010 07:27 PM
I wish I would have seen this thread before replacing the switch. Great write up!
danvdd 11-07-2010 01:56 PM
Just fixed mine. It took over 6 months to get to it but it went off without a hitch.:2thumbsup:
The time now is 09:47 AM.
