Repairing a Clogged AC Drain - JeepForum.com
post #1 of 162 Old 01-01-2008, 09:00 AM Thread Starter
PunisherZJ
I know this topic has been covered, I actually learned how to do it from this site. One thing I could not find is any actual photos of the process. I took some photos of the job to help others with the same problem.
I had moisture on the passenger side floor pan of my 97 GC 5.2L. It didn't feel or smell like antifreeze so I eliminated the heater core as an issue. I learned from members of Jeepforum that it was possibly a clogged AC drain. Using the recommendations from others I started the job.
Locate the HVAC box drain by pulling the carpet back on the passenger side. Its a round piece that goes into the firewall.
Drill a 1/4 inch hole into drain
Blow out with air
I wasn't able to locate a rubber plug to plug the hole but I did find find a plastic fastener for interior trim. Once I can locate a rubber plug to fit, I plan on changing it out.
Applied a bit of Goop to help seal
Installed plug then cover surface with more Goop to ensure a good seal
PunisherZJ is offline
post #2 of 162 Old 01-01-2008, 11:27 AM
Dillonzj
Blow out with air
nice pictures
98' JEEP GRAND CHEROKEE LIMITED 5.9
149k 5.9L v8 White
Crane Cam shaft and Crane, Roller Rockers, bored .030 over, edelbrock performer heads, M1 Intake manifold, Fasstman throttle body, magnacore wires, platinum plugs, K&N FIPK, dough thorley headers,3" high flow cat, 3" magnaflow mandrel bent exhaust, SCT tuned
***future mods -5.5 IRO LA - KOR sliders -KOR roof rack -
SOLD-
95' JEEP GRAND CHEROKEE LIMITED
188k 5.2L v8 White 98 ZJ rims
Originally Posted by nashmd454 View Post
...we all know they empty our pockets...yet they fill our hearts...
Dillonzj is offline
post #3 of 162 Old 01-01-2008, 11:30 AM Thread Starter
PunisherZJ
Originally Posted by Dillonzj
nice pictures
Thanks! How did you get them to open on the thread? I used the img tags but it just showed the link.
post #4 of 162 Old 01-01-2008, 11:33 AM
Darthteddy
1955 M-38
Must have 50 posts and be here a month to have pictures show up. Great write up. If mine ever clogs, now ill know what to do.
Dylan-19 and Yearning
93 Rubigrand - Sold... :'(
95 Grand Cherokee Limited - 5.2 Mall Crawler
55 Willy's M38a1 - 231v6, 33" Super Swampers, D44 Full Floater Rear, Locked Front and Rear, 5.38 Gears, Viair OBA, Bilsteen 5100 shocks, Dana 18, Turbo 350, S10 Power Steering, Tilt-wheel, Full Cage, Flat Fenders....
Darthteddy is offline
post #5 of 162 Old 01-01-2008, 11:35 AM Thread Starter
PunisherZJ
Oh okThat makes since. I just went out and changed that plug to a rubber plug. I'll update the thread in a bit.
post #6 of 162 Old 01-01-2008, 03:11 PM Thread Starter
PunisherZJ
As I mentioned above, I changed my mind about using that plastic trim fastener for a plug. I went to Advanced Auto Parts and grabbed a set of universal plugs:
Found one that somewhat fit but had to shave it a bit to make it fit tight and go all the way in the hole:
Added Goop to seal it...all done
post #7 of 162 Old 01-01-2008, 04:47 PM
Dillonzj
pictures!
149k 5.9L v8 White
SOLD-
Dillonzj is offline
post #8 of 162 Old 01-01-2008, 05:15 PM
Turbonut
Great writeup if the drain is clogged, but many times the seal at the firewall deteriorates and allows water to run back into the comparment when the Jeep is uphill.
Turbonut is offline
post #9 of 162 Old 01-01-2008, 05:44 PM Thread Starter
PunisherZJ
pictures!
Thanks!
post #10 of 162 Old 01-01-2008, 05:46 PM Thread Starter
PunisherZJ
I'm hoping this was the problem. Guess I'll know in a few days. I'll look into that if I still have an issue.
post #11 of 162 Old 01-02-2008, 05:38 AM
georged
Just looked at the picture of the package of assorted bumpers. It looks like one of them would be perfect for the gas door bumpers that seem to disppear.
georged is offline
post #12 of 162 Old 01-02-2008, 05:43 AM
coonash
coonash's Avatar
that is my problem.
Originally Posted by 5-90
This is an online forum, and the written word is the primary method of communication. If you make an effort to communicate clearly, people will be willing to communicate in return. If you don't make an effort, I don't see why I should - write like an idiot, and I'm going to think you're an idiot, that's just how things work.
USN Jeep Club Number 41
coonash is offline
post #13 of 162 Old 01-02-2008, 09:27 AM
Turbonut
Originally Posted by coonash
that is my problem.
Well, your PM's are filled, but you need to cut a 2" x 3" access hole behond the right front wheel. Then attach either a curved hose to the drain, or since I had a large plastic washer in the garage, I applied silicone around the tube at the firewall and slid the washer over into the silicone and against the firewall. Covered 2 x 3 hole with sheet metal and undercoating. Never leaked again.
I did this back in 1998 and was fine when the Jeep was sold in 2003.
Turbonut is offline
post #14 of 162 Old 01-02-2008, 10:42 AM
FPKites
ZJjazzyJim
FPKites's Avatar
Wonderful writeup! Needs to be sent to the tech articles section!
Jim Karlin
"Duh! Big RED Jeep!!!"
or
96 ZJ Laredo
5" lift, Claytons, KOR radiator support, rear bumper, steering brace, etc, etc, etc.
04 WJ Overland
Clean.... :D
FPKites is offline
post #15 of 162 Old 01-04-2008, 05:36 PM
swataz
I have the same problem with no AC drainage, and this is all great info and I will attempt it soon.
My question is this -- is there NO way to access the drain tube on the engine side of the firewall?
swataz is offline
Radiator Drain Plug? Coolant wont drain epfriis ZJ Grand Cherokee Forum 6 06-18-2015 12:18 PM
Condensation Drain Tude: Clogged sandblaster426 ZJ Grand Cherokee Forum 15 07-12-2014 08:09 PM
a/c drain clogged 97zjjeeper ZJ Grand Cherokee Forum 5 07-29-2008 04:45 PM
A/C Drain clogged...3 inches of water...UHOH!! li'l jeep ZJ Grand Cherokee Forum 2 07-27-2008 01:20 PM
Clogged AC drain tube? lma1973 ZJ Grand Cherokee Forum 14 11-26-2006 05:32 PM
