Removing Wiper Arms On 98 ZJ? - JeepForum.com
post #1 of 4 Old 02-22-2008, 08:11 PM Thread Starter
ThroatyStang
Anyone tell me how to do this?
ThroatyStang is offline
post #2 of 4 Old 02-23-2008, 01:41 PM Thread Starter
ThroatyStang
Anyone know?
post #3 of 4 Old 02-23-2008, 02:19 PM
_Kyle_
_Kyle_'s Avatar
From my '96 ZJ FSM.
FRONT
CAUTION: The use of a screwdriver or other prying
tool to remove a wiper arm may distort it. This distortion
could allow the arm to come off of the pivot
shaft, regardless of how carefully it is installed.
(1) Open the vehicleís hood.
(2) Lift the wiper arm to permit the latch to be
pulled out to its holding position, then release the
arm (Fig. 5). The arm will remain off the windshield
with the latch in this position.
(3) Remove the arm from the pivot using a rocking
motion.
(4) Install the arm and blade with the wiper motor
in the Park position. See the Wiper Arm Installation
illustration (Fig. 6). Mount the arms on the pivot
shafts so that the distance from the lower edge of the
wiper arm tip to the upper edge of the lower windshield
moulding is:
≤ 25 - 52 mm (0.98 - 2.04 inch) on the driverís side
≤ 33 - 62 mm (1.29 - 2.44 inch) on the passengerís
side.
(5) Lift the wiper arm away from the windshield
slightly to relieve the spring tension on the locking
latch. Push the latch into the locked position and
slowly release the arm until the wiper blade rests on
the windshield.
(6) Operate the wipers with the windshield glass
wet, then turn the wiper switch to the Off position.
Check for the correct wiper arm positioning and readjust
if required.
-Kyle
1996 Grand Cherokee
2005 Wrangler Rocky Mountain Edition
RIP Troy (bigbluezj94)
_Kyle_ is offline
post #4 of 4 Old 02-23-2008, 08:38 PM
greasefingers
greasefingers's Avatar
1994 ZJ
They are a PITA as they have limited access. A tiny puller might work. Good luck trying to rock them back & forth. They are usually stuck on like glue!
Cheers Steve
94 Black Laredo 4-Liter with QuadraTrac (42RE trans & NP249 TC) 200,000 + miles purchased new
88 Cherokee 2-door with 5speed manual 139K miles(deceased) purchased new
greasefingers is offline
need help removing wiper arms on ZJ jeepguy2008 ZJ Grand Cherokee Forum 8 10-24-2008 08:05 PM
Removing Wiper Arms highryder08 ZJ Grand Cherokee Forum 3 12-21-2007 05:10 PM
Removing wiper arms mmstone ZJ Grand Cherokee Forum 8 02-10-2007 09:47 PM
removing wiper arms 99JEEP ZJ Grand Cherokee Forum 3 06-26-2005 07:51 PM
Removing Wiper Arms Kcolg ZJ Grand Cherokee Forum 1 03-07-2005 09:29 PM
