Removing timing cover - JeepForum.com
post #1 of 5 Old 10-22-2011, 05:36 PM Thread Starter
Yekknom
1994 ZJ
How simple is it to remove this? 3 weeks ago I replaced the water pump now I have to replace to cover due to it cracking. And I'm not sure how to do this. I'll read through my Haynes manual but I was hoping someone could break it down and explain exactly how to do it
Yekknom is offline
post #2 of 5 Old 10-22-2011, 05:37 PM
Candymancan
Easy, the bolts holding the water pump also are the bolts holding the timing cover.. cept 2 bolts on the bottom of the oil pan, and i believe 2 others further down. Remove the power steering pump, a/c compressor, alternator, and fan clutch, and then take all the bolts off including the 2 on the oil pan, and it should pop out.
Candymancan is offline
post #3 of 5 Old 10-22-2011, 06:21 PM Thread Starter
Yekknom
1994 ZJ
So I should take off the oils pan too? Or what
Yekknom is offline
post #4 of 5 Old 10-22-2011, 06:45 PM
newfieZJ
No , just the first 2 , maybe 3 bolts on each side towards the front .
Not mentioned was needing to pull off the harmonic balancer . You'll need the puller for that .
newfieZJ is offline
post #5 of 5 Old 10-22-2011, 10:12 PM Thread Starter
Yekknom
1994 ZJ
Sounds complicated
Yekknom is offline
