removing lower control arms - JeepForum.com
post #1 of 8 Old 01-03-2017, 12:18 PM Thread Starter
cblake0619
So my buddy and I are certified garage mechanics at this point and have replaced a ridiculous amount of stuff on my 97 Laredo v8.
The newest fix is the control arm bushings. Naturally bushings are the worst thing to remove and repack so I bought brand new control arms to pop in there, what's holding us back is the bolt is most likely rusted to the bushing and turning is getting us nowhere. I've read a bit about just cutting the bushing with a sawzall and such but just not sure where to cut or if I should angle grind through the old control arm and have each side spinning freely. Any help would be appreciated
cblake0619 is offline
post #2 of 8 Old 01-03-2017, 04:35 PM
biffgnar
biffgnar's Avatar
Moved to ZJ Tech.
No experience with a ZJ, but with a TJ or an XJ I'd try to get the sawzall between the inside of the bracket and the bushing so I was cutting the bolt on either/both side(s) of the bushing.
Romney in 2020!
biffgnar is offline
post #3 of 8 Old 01-03-2017, 04:46 PM
vpt28777
**************Help***********
I have a Jeep Liberty sport 3.7L 4x4
The code said today is:
P0352
- ignition coil B , primary / secondary
- circuit malfunction
****Help please*****
I have a picture and video but don't let me upload
vpt28777 is offline
post #4 of 8 Old 01-03-2017, 08:17 PM Thread Starter
cblake0619
That's what I was assuming. Any specific dimensions for the bolt to replace and any specific areas for jack stands or will just the frame work?
post #5 of 8 Old 01-03-2017, 09:29 PM
kg6mov
Hears the voices
kg6mov's Avatar
@biffgnar the front end of a ZJ is identical to its TJ/XJ brethren.
You want jack stands near the LCA frame side brackets, the "frame" isn't and will bend if you put pressure in the wrong place. I sure wouldn't try to get a sawzall into the CA bracket, but I don't deal with real rust. I can't imagine one of those bolts not being able to come out if you can get the nut off though . . .
kg6mov is offline
post #6 of 8 Old 01-03-2017, 09:31 PM
biffgnar
biffgnar's Avatar
Thanks.
For what it's worth, I have seen bolts seized to the sleeve in the bushing before. It can happen.
Romney in 2020!
biffgnar is offline
post #7 of 8 Old 01-04-2017, 02:15 AM
Timo_90xj
Timo_90xj's Avatar
Especially LCA bolts frequently completely seize into the bushing sleeves on areas where road salt is used extensively. On a Jeep that hasn't seen OEM suspension parts pulled out since it left the factory, especially CA and trackbar bolts can be seized so bad into the bushings that the only option is to cut them.
I always use a ton of marine-grade salt-water proof grease when installing bolts into control arms and track bars - yet I just recently had one bolt seize into the rear axleside UCA bushing sleeve being there only for four years
Use either a 4.5" or 8" angle grinder, and cut the bolts from both sides of the bushings. 4.5" with a thin cut-off wheel (for stainless steel) should reach about halfway through the bolt, then spin it a little and cut the rest.
It's more precise with the 4.5" grinder so you won't cut as easily into the brackets.
You can use a sawzall as well, but it's about a gazillion times slower and more work IMHO. It takes about 20 seconds to cut one bolt on both sides of the bushing
Keep the cut-off disc as close to the CA/ bushing as possible, avoid cutting into the bracket.
***Under construction***
Timo_90xj is offline
post #8 of 8 Old 01-04-2017, 10:18 PM
CatSplat
1994 ZJ
The #1 best way to cut CA bolts (IMO) is a Sawzall with a Freud Steel Demon carbide-tipped blade. They are a bit pricier than regular metal blades, but they cut through suspension bolts like butter, it's incredible. I was working on a Nissan UCA with seized bolts a couple months back and that blade did in 10 seconds what my Lenox metal blades couldn't achieve in a half hour of sawing.
1994 5.9L ZJ, retrofitted UC package, NP242 swap, 17" JK Moabs with 32" BFG MT KM's.
The Jeep of Theseus
CatSplat is offline
