-   -   Removing AC System questions. (http://www.jeepforum.com/forum/f13/removing-ac-system-questions-1611449/)
Scopez 09-22-2013 09:50 AM
On my 96 5.2L ZJ, I plan on removing the condenser, dryer and the compressor mainly because I don't use it and the compressor squeals. Yes I know the AC is used for defrost to help with the moisture, but I'll live. I was looking under the Hood and saw a hose from the dryer going into the firewall, what do I with that? Any easy was to relieve the pressure on the lines? Or should I just unbolt and pull everything with the pressure? I've searched and only came up with the 4.0. Man...where's Ratmonkey when you need him? RIP my friend.
HighLonesome 09-22-2013 10:02 AM
Yea not the same here without Ratmonkey RIP
I removed all this stuff from my 94. I think you mean the hose goes to the evaporator. Just disconnect it and plug the hole at the firewall. You can release the pressure at the shraeder valve on lowside fill port. But that is illegal of course, you are supposed to have the freon professionally evacuated for recycling.
Scopez 09-22-2013 10:41 AM
Originally Posted by HighLonesome
Yea not the same here without Ratmonkey RIP I removed all this stuff from my 94. I think you mean the hose goes to the evaporator. Just disconnect it and plug the hole at the firewall. You can release the pressure at the shraeder valve on lowside fill port. But that is illegal of course, you are supposed to have the freon professionally evacuated for recycling.
Ah okay, then ill vacuum it all out tomorrow. But it's pretty simply and straight forward right?
HighLonesome 09-22-2013 10:59 AM
very
you need AC disconnect tool tho and the short serp belt
Scopez 09-22-2013 12:03 PM
very you need AC disconnect tool tho and the short serp belt
I'm throwing one of those bypass pulleys on. I work at a shop off and on, so I have access to all the tools needed.
Thanks for the info though!
ghiotom 09-22-2013 01:52 PM
You live in Aiken. SC and you want to get rid of your AC? No offense, but that's the hottest hellhole in the southeast! That hose is part of the accumulator, it's one piece from the evaporator to the compressor.
Scopez 09-22-2013 03:12 PM
The high all year was 96....I still had my windows down. It's 83 right now.
HighLonesome 09-22-2013 03:31 PM
Been using Miracool. On the worst of days, one as a headband and one around the neck. Spares are kept in the cooler and swapped out every couple hours.
The time now is 02:06 AM.
