Removing ABS fuse? - JeepForum.com
post #1 of 2 Old 10-03-2013, 11:00 AM Thread Starter
Deadhorse
Removing ABS fuse?
I want to disable my ABS as it's malfunctioning and read a post about removing the fuse to do this but there are two ABS fuses in the box behind the battery, one for the ABS valve and one for the pump? I don't want to damage the system any more so which one is it?
Deadhorse is offline
post #2 of 2 Old 10-03-2013, 12:06 PM
Timo_90xj
Timo_90xj's Avatar
Remove all ABS- related fuses. One in the passenger side of the vehicle in the cab., other in the PDC.
You will not cause damage to anything. I keep my ABS deactivated most of the year, I only plug in the fuses when I go get the vehicle for the annual inspection.
***Under construction***
Timo_90xj is online now
