Remove Front Bumper - Page 2 - JeepForum.com
post #16 of 19 Old 02-10-2013, 08:25 AM
CGlaser
I cut off that metal support. Heated the part of the fram that was bent (only part when it actually connects to that support was bent on mine) straightened it out. And built a bumper that slips into that frame. But i dont know if the damage is that extensive.
http://www.jeepforum.com/forum/f22/98-zj-slow-build-1484672/
CGlaser is offline
post #17 of 19 Old 02-10-2013, 10:04 AM Thread Starter
96ZJVT
I don't have those skills or tools. I'm just starting out and I don't know anything.
I ended up just installing the passenger side front tow hook.
96ZJVT is offline
post #18 of 19 Old 02-10-2013, 10:14 AM
riot1987
Originally Posted by 96ZJVT View Post
After I got the grille and bumper fascia off I found that the drivers side had been in an accident, the frame is bent and it seems impossible to get that tow hook bracket to line up for install.
The radiator and mounting brackets are also bent and in the way of progress.
Missing hardware, mismatched hardware...
Embarrassing...
I suck.
MNo way man. No way to really see some of that **** till you take it apart. As far as repairing the unibody thats kinda tough. Use some heat and a hammer. Maybe you can persuade it if its not too bad?
Build thread^^
riot1987 is offline
post #19 of 19 Old 02-10-2013, 10:27 AM
CGlaser
This is what mine looked like after i removed that support. Where the frame comes out (where it used to connect to the factory bumper support) on the drivers side was bent. We heated it. And beat it as straightened it as well as we could. I forgot i cant post a picture yet..
CGlaser is offline
