remove blinker assy - how - JeepForum.com
post #1 of 3 Old 07-13-2002, 09:47 PM Thread Starter
mnjeepster
The bulb is burnt out. I only found 1 screw under the hood on top....help -passenger side
mnjeepster is offline
post #2 of 3 Old 07-13-2002, 10:29 PM
Drafter75
Assuming that your talking about the turn signal bulb on a 93-98 ZJ...
The turn signal and headlight housings are separate assemblies. You don't need to remove the headlight. The turn signal assembly has a couple of screws along the top of the housing.
These are not easy to see or get to because there's not much of a gap between the headlight and signal housings. It's a p-poor design. You need to wedge something between the two housings and GENTLY pry them apart so you can get a driver in to those screws.
It's been a long time since I've changed one of these bulbs and I can't remember if there are any other screws holding the housing in place, so you'll have to look for any others. All I remember was that it was a royal pain to get at the screws I mentioned.
Drafter75
Proud V8 ZJ/WJ owner of
1993-1998-1999-2002 model years.
Have you hugged your Jeep today?
Drafter75 is offline
post #3 of 3 Old 07-14-2002, 02:41 PM
ski zj
ski zj's Avatar
ok design, but as Drafter75 noted - kinda tricky to find;
there are two Torx screws holding in each of the two turn signal housings.
the Corner Marker/turn signal Housing is held by one on top, under the corner of the hood - which you've already found,
the second is squeezed in under the bottom edge of the corner marker housing.
the Front Running Lamp/turn signal Housing may now be removed by removal of the two screws accessed from the upper inside cavity, where the corner marker was positioned.
1996 GrandCherokee Limited
she see's more of the white stuff than the brown stuff!
ski zj is offline
ZJ headlamp assy mounting clip HighLonesome ZJ Grand Cherokee Forum 2 12-25-2008 09:16 AM
axle assy swap trailboy ZJ Grand Cherokee Forum 1 11-27-2007 05:47 PM
06' Wk front wheel hub & bearing assy joe_mtz WK Grand Cherokee & XK Commander Forum 2 03-08-2007 09:38 PM
Axle Assy questions avusblau ZJ Grand Cherokee Forum 2 11-22-2004 02:51 PM
New caliper assy ? elvisdk ZJ Grand Cherokee Forum 5 09-16-2004 03:43 PM
