Removal of rear sway bar? - Page 2 - JeepForum.com
post #16 of 23 Old 10-08-2013, 10:39 AM
PolkaPower
Originally Posted by no9avenger View Post
I would def go with that in the rear( better than a used one from a junk yard) but would a front one be compatible with my quick disconnects ?
I have a front ADDCO and it works with my JKS. There are two ways to bolt it together. One is that you shave the ends of the bar with a grinder, the other is that you bolt it under instead of over.
PolkaPower is offline
post #17 of 23 Old 10-08-2013, 05:15 PM
riot1987
My front worked fine with my discos
Build thread^^
riot1987 is offline
post #18 of 23 Old 10-08-2013, 05:20 PM
HighLonesome
Belief In All Things Jeep
HighLonesome's Avatar
Originally Posted by WhiteOut View Post
There is pretty much no improvement in flex with the rear removed. It's so small that it doesn't hinder you, but you WILL notice it gone at 45+ speeds.
x4 on that. With stock control arms, it makes little or no difference.
HighLonesome is offline
post #19 of 23 Old 11-12-2013, 03:48 PM
craftworks125
I have no front swaybar. I just replaced a link in the rear and the first time I flexed out the rear swaybar itself sheered. Is this because I have no front swaybar?
craftworks125 is offline
post #20 of 23 Old 11-12-2013, 03:58 PM
JasonStebbins
I haven't had a rear sway bar in years and have had no ill affects. I drive on the expressway every week and being lifted on 33" tires in a vehicle with zero aerodynamics, you're going to get pushed around by the wind regardless. Definitely no flex benefits without one though.
Poop
JasonStebbins is offline
post #21 of 23 Old 11-12-2013, 11:19 PM
Myusername1674
I have run no rear sway bar for about a year now. The reason that I removed it was because of some back yard wheeling. I was attempting to climb a stump with the front discoed and rear bar connected. I wasn't able to get my jeep up the stump because the rear came off the ground just enough to spin and stop forward movement. I then removed the rear sway bar as well as disco-ing the front. Once I did this I was able to climb the same stump without the tires coming off the ground. Now it's possible it was all just luck that I climbed it fine without the rear sway bar, but I tend to think it is more because the sway bar was off. All that to say I haven't been running one since and it's somewhat noticeable on the street, but nothing life threatening; it just means you can't corner like a sports car
95 FiveTwo ZJ, DD, Lifted, Locked on 35s,
(in progress)
Myusername1674 is offline
post #22 of 23 Old 11-13-2013, 07:21 AM
craftworks125
So is it ok to run just a rear swaybar or will it snap again?
post #23 of 23 Old 11-13-2013, 03:56 PM
JasonStebbins
The OEM bar is tiny. It will snap eventually. If you want to run one, upgrade to a beefier one.
Poop
