Removal of rear sway bar? - JeepForum.com
post #1 of 23 Old 10-07-2013, 04:31 PM Thread Starter
no9avenger
The rear sway bar in my 98 zj limited was bent, so I manages to bend it to a point were I could through some new mounting brackets on , only problem is now because its bent the brackets squeak like hell when I hit a bump and I'm contemplating just removing it Untill i can get a Replacement one .Opinions ?
no9avenger is offline
post #2 of 23 Old 10-07-2013, 04:47 PM
dave_dj1
I have mine removed but now that I have 6" lift I am contemplating putting it back in! Stock height it was ok without it.
Wheel it like ya stole it!
dave_dj1 is offline
post #3 of 23 Old 10-07-2013, 05:06 PM Thread Starter
no9avenger
I have a 3.5 lift on it and I don't drive it much cause its more of my weekend toy
post #4 of 23 Old 10-07-2013, 05:13 PM
chadcmb
everyone on our offroad forum in alaska said to remove it for flex.
wont notice much roll
i have 3-4inches with 31s.
chadcmb is offline
post #5 of 23 Old 10-07-2013, 06:28 PM
David97
I'm at 4.5" on 32s, and no rear sway bar as the PO removed it. If most of your driving is around town, you probably wont notice it a whole lot. However on the interstate, you can feel it, as it feels like your rear end is swaying back and forth. Especially on windier days.
But if like you said, and you don't drive it a whole lot, you'll be fine without it. Wont notice much of a huge difference really, but you will know that it isn't there, and will feel it not being there. Just my experience.
David97 is offline
post #6 of 23 Old 10-07-2013, 08:46 PM
WhiteOut
WhiteOut's Avatar
There is pretty much no improvement in flex with the rear removed. It's so small that it doesn't hinder you, but you WILL notice it gone at 45+ speeds.
WhiteOut is offline
post #7 of 23 Old 10-07-2013, 09:18 PM
riot1987
^^this. Especially in a lifted ZJ.
Build thread^^
riot1987 is offline
post #8 of 23 Old 10-08-2013, 02:16 AM
Timo_90xj
Timo_90xj's Avatar
I agree.
You actually want some body sway control on the trails as well - not just on the road. A fully disconnected coil-sprung vehicle isn't exactly the best to wheel around when in some tighter "pucker-factor" spots. I'd actually prefer setting up Currie anti-rock for the front and either keep the stock rear or upgrade to an anti-rock there as well instead of running front fully disco'd.
There isn't much difference in rear wheel articualtion with the rear sway bar connected, but it does provide some sway control nevertheless. On the highways, front sway bar does most of the work though..
In short, get a new one and run it without the rear until you find one.
***Under construction***
Timo_90xj is online now
post #9 of 23 Old 10-08-2013, 06:29 AM Thread Starter
no9avenger
Well I plan in replacing it soon its just the sqeaking annoys me alot ha , tomorrow will be the first time it's on the highway to get get tires mounted and balanced maybe ill just take it off after as a precautionary movement
post #10 of 23 Old 10-08-2013, 06:55 AM
kbranderhorst
I drove mine with out front sway bar links for a while and that was a little nerve racking but the rear one shouldn't be as crucial, what it sounds like you need is some new bushings not that much money ....
kbranderhorst is offline
post #11 of 23 Old 10-08-2013, 07:03 AM Thread Starter
no9avenger
I have the quick disconnects in the front and I drove around with them off for a little and it was noticeable.
post #12 of 23 Old 10-08-2013, 08:17 AM
PolkaPower
You should upgrade to the ADDCO rear swaybar. Then later add the front.
PolkaPower is online now
post #13 of 23 Old 10-08-2013, 09:29 AM
JohnnyZJ
coil sprung vehicle with no sway bars, think of a jeep sitting on top of 4 slinkies.
that said, do you have a front sway bar? hook it up and you can take the rear off until you get a new one, that will be fine. addco or whatnots a good upgrade.
i drive around with my front unhooked all the time. might even take it off. i keep the rear on at all times. the rear one is really wimpy, so it doesn't hinder flexability much at all, but provides enough rigidity to keep the jeep stable.
07' JKUR rollin on 35s
JohnnyZJ is offline
post #14 of 23 Old 10-08-2013, 09:34 AM Thread Starter
no9avenger
I would def go with that in the rear( better than a used one from a junk yard) but would a front one be compatible with my quick disconnects ?
post #15 of 23 Old 10-08-2013, 09:36 AM Thread Starter
no9avenger
I have the front one and its always connected ,I've owned the jeep for 3 months and have only put 300 miles on it ( I usually drive it on the weekends so I don't have to drive my commuter car around and to keep the engine running ) so there should be no harm me just taking it off until I get a new one .
