Remote Start for 97 Grand Cherokee With Door Remotes - JeepForum.com
post #1 of 11 Old 12-29-2011, 12:26 PM Thread Starter
97GRCherokee
Hi,
I am looking into getting a Remote Start for my 97 Grand cherokee with the 4.0 inline 6
My Jeep has power Locks, but It does not have keyless entry I dont have a FOB for the locks.
Is there a remote start that I can have installed that locks and unlocks my doors as well??
Thanks in advance
97GRCherokee is offline
post #2 of 11 Old 12-29-2011, 01:35 PM
Mickey_D
http://www.bulldogsecurity.com/Produ...ess-entry.aspx
There ya go. Everything you'll need and they have wiring diagrams, "T" connectors, everything you'll need to do a full DIY installation. I've used them on 5 vehicles now. Do yourself a favor and ONLY get the 1300 series. More options (low battery auto start, low temp auto start, etc) and better range.
The remotes will let you unlock the doors, roll down a window, start the vehicle and (if you're creative) crank up the rear defroster. All from up to 300 feet away. I had them in Minnesota and it was SOOOO nice to not even have to go outside the house to fire the car/truck up.
1997 ZJ 5.2 Orvis, Baby!
1953 Willys M100 trailer Tagalong
________________
[_][][][][][][][][_]
#4
Mickey_D is offline
post #3 of 11 Old 12-29-2011, 05:16 PM
coralman
USER OF PARTS CATALOGS
coralman's Avatar
What about one that does have keyless entry? Any recommendations?
coralman is online now
post #4 of 11 Old 12-29-2011, 06:08 PM
ZeeJay1997
You and your toys lol
ZeeJay1997 is offline
post #5 of 11 Old 12-29-2011, 07:27 PM
coralman
coralman's Avatar
LOL, you know me too well! Will have a axle in my backyard soon. Girlfriend says she's gonna put me on the hoarders tv show if I don't stop.
post #6 of 11 Old 04-05-2012, 08:02 PM
VandE
2004 XJ Cherokee
Auto start makes the alarm go off & wont shut off ~how does one disconnect the alarm?
New to the forum ~ We have a CompuSTAR auto start for our 2004 Special Edition & this morning we went to autostart like every am & our alarm came on and would not turn off w/ the remote & also when we went out & tried to do it manually so we had to unhook the battery & take cabs. Does anyone have any ideas on how to unhook/disconnect our alarm system until we can bring it in this weekend to fix it? Any suggestions would be appreciated thx
VandE is offline
post #7 of 11 Old 04-05-2012, 10:21 PM
Mickey_D
From what I know (and that's a little limited) you're looking at a tow truck.
I do believe if you try to make the alarm inoperative, you'll also make the vehicle just as inoperative because it goes inline to the ignition, fuel delivery, etc. Taking the alarm out of the loop without putting all the wiring back to factory is next to impossible.
So it's either taking the alarm completely back out and restoring the wiring to factory, or fixing the alarm.
________________
#4
Mickey_D is offline
post #8 of 11 Old 04-06-2012, 04:10 AM
341012
OEM remote start:
http://thehoffmangroup.com/stellar/d...?itemid=RS1050 - $99
it works off of 2 negative input triggers on one wire. hook it up with your locking output wires and there you have it. I have installed this on mine (with a aftermarket alarm), on a honda crv and a ford f350.
They sell them on ebay stating OEM specific, but its the same one.
http://www.ebay.com/itm/Pontiac-Fier...item27bf0d3dc3 - $75
that's the cheapest i could find.
it looks like bulldog has a better combo for the keyless+remote start, but they sell separate keyless systems too
http://www.autoloc.com/catalog/produ...ess-Entry-Unit - $55
Edit: I forgot to mention they have a flipkey keyfob, I thought it was cool but they dont make it for my alarm, only for a couple keyless systems
http://www.autoloc.com/catalog/FlipK...REMOTE-ONLY---
341012 is offline
post #9 of 11 Old 04-06-2012, 04:19 AM
341012
most likely the biggest change having the alarm will be that your starter output from your ignition has been interrupted; thats usually the biggest change, rather then outputs and inputs from various sources (acc, ign, brake, door trigger, headlights, horn/siren, locks, etc) that wont make a difference because the circuit is not completely interrupted.
like stated before, you have to change the wiring back to factory (it may be more so then disconnect power + ground and starter wire reconnect, just stating whats typical) and completely disconnect the wiring to the unit.
do you have the paperwork that came with it? model # or anything?
341012 is offline
post #10 of 11 Old 04-06-2012, 09:37 AM
moldeck
disarming alarm
unlock and lock with the key a few times and the alarm will disarm (mine only works on the passenger side door) and you will be able to start your jeep. manually lock the doors and do not use the lock button on the inside for all doors or the fob, and the alarm will not set.
moldeck is offline
post #11 of 11 Old 04-14-2012, 08:05 PM
VandE
2004 XJ Cherokee
Thanks for the suggestions...
Before I read your msg's we ended up trying everything before we had it towed to the auto start place & they spent an hour trying to fix it & ended up saying that it was a car computer problem, towed it to Jeep & ended up costing $398. to rewire back to factory. It is fixed but sans the auto start. It (compuSTAR) was an older 2-way model that was discontinued so we figured it would b better to upgrade to a new model anyway. Thanks again for the input.
Lesson learned.
VandE is offline
2004 Grand Cherokee Rocky Mountain Edition WJ Remote Start TheMadMax ZJ Grand Cherokee Forum 2 01-19-2010 07:14 AM
help with remote start on 2003 jeep grand cherokee limited jeepwonder ZJ Grand Cherokee Forum 10 01-11-2010 07:20 PM
WK Jeep Grand Cherokee Mopar Factory Remote Start Problem daxlw WK Grand Cherokee & XK Commander Forum 1 05-12-2009 01:51 PM
07 key to remote start 05 Grand Cherokee autoenglish WK Grand Cherokee & XK Commander Forum 7 02-28-2009 01:16 PM
disable horn chirp remote start 06 grand djvan WK Grand Cherokee & XK Commander Forum 7 02-13-2009 08:57 PM
