Remote Keyless Entry with almost no range - JeepForum.com
post #1 of 9 Old 09-04-2008, 07:53 AM Thread Starter
EngineerJoe
Hey Everybody,
Although I've been a member here for just over a year now, this is only my 2nd post, so I should probably introduce myself and my Jeep! Ok, it's not MY Jeep, it's my girlfriend's. I'm saving my money for an '04-'06 Rubi.
Anyway, my g/f recently acquired an '04 GCL (Rocky Mountain Edition) with the 4.0L and d30/35. It's a great vehicle for the mileage, but does have some work required.
The problem I'm having is that the remote keyless entry FOBs (RKE FOBs) don't work if you're more than 2' from the vehicle. I've replaced the batteries and even placed the green electrical panel into a new RKE FOB and still nothing. I've had many Chrysler vehicles before, and the RKE FOBs almost always work for at least 80'. So, any suggestions as to what could be the problem?
EngineerJoe is offline
post #2 of 9 Old 09-04-2008, 08:08 AM
nierace
nierace's Avatar
2003 WJ
Mine is the same way but I have dropped my key fobs under in water quite a few times, I'd be willing to bet your previous owner did the same. You can pick up the fobs off ebay for <$20 and they are really easy to program.
Even new though mine never worked from 80' away...
Nickerdoodle
03 WJ 4.7 242HD Kolak/IRO 5" Clayton LA's
35" BFGoodrich KM2
North East Offroad Club
nierace is offline
post #3 of 9 Old 09-04-2008, 08:33 AM
SJZ
Victim of Hope & Change
SJZ's Avatar
Location: . . . . . . . . . . . . . . . A shining city upon a hill
As an aside, if you hold the remote to your chin, it increases the distance. Really, try it!
To the OP: nierace is right, buy a new remote.
-Steve
"Those who hammer their guns into plows, will plow for those who do not." -Thomas Jefferson
___________________________________________
'98 ZJ Laredo 5.2 Selec-Trac (249 to 242 swap)
'05 KJ Limited 3.7 Selec-Trac
'94 ZJ Limited 5.2 Q-Trac- sold, after 17 years
'67 International Harvester Scout 800; 345ci V8,T18 4spd, Dana 20 TC
'06 Chrysler 300C SRT8 6.1L
SJZ is offline
post #4 of 9 Old 09-04-2008, 10:15 AM
Texas ZJ1
Jeep Jedi Master
Texas ZJ1's Avatar
1994 ZJ
Are the windows tinted? If so, it'll decrease the distance dramatically.
Hunter
04 4.7 HO, limited
08 Z71 Suburban, front leveling kit with rear spacers. 285/65 18s Nitto TerraGrappler G2s
94 5.9 Laredo 6.5 RE lift with 35 Maxxis Bighorns
and 33 Bridgestone Duelers
Detroit and true trac
Red Jeep Club Member
REDNECK JCM
Texas Jeep Owner #6
USN Jeep Club #4
602.841.3355
For your performance needs:
480.998.366
Texas ZJ1 is offline
post #5 of 9 Old 09-04-2008, 12:15 PM Thread Starter
EngineerJoe
Thanks for the response guys. Something tells me I'm really going to like this forum.
The 80' distance is what I've been able to get with my '04 Intrepid, but would require me to press the buttons a couple times. As far as tint, If I'm not mistaken, it's factory tint only.
Correct me if I'm wrong, but I believe the RKE module is in the dash. I am considering adding an antenna extender, or switching to an after market alarm.
post #6 of 9 Old 09-04-2008, 12:21 PM
nierace
nierace's Avatar
2003 WJ
If you want range get a remote starter...then you can start it and unlock it from two miles away.
That may not be a good thing though :P
Nickerdoodle
35" BFGoodrich KM2
nierace is offline
post #7 of 9 Old 09-05-2008, 08:52 AM
CJHVN
Same deal here. 2000 GC and the remotes suck. I'd be happy if they worked within 5 feet. New batteries don't help. Is the remote worn out? Would a new one work? What's the RKE? Does something need to be done on the vehicle itself? Can the RKE be replaced?
I've seen new fobs on ebay. How easy are they to program? What's the process?
Thanks!
85 CJ-7, 4.0L, twin stick/clocked flat Dana 300, SOA, 36" TSL's, 30/44 locked, Warn X8000i
92 XJ, 4.0L, AW4, Dropped NP231, 30/8.25, 4" DPG Hybrid lift, 33" MT/R's, JKS trackbar, JKS discos, OME Nitro Shocks, stinger bumper, Warn X8000i, etc. (work in progress)
CJHVN is offline
post #8 of 9 Old 09-05-2008, 09:28 AM Thread Starter
EngineerJoe
RKE = Remote Keyless Entry
Chrysler has several styles and you have to make sure the one you get is compatible with your WJ. To add an RKE FOB, it's in your user manual. I'd explain it, but I don't have the manual here.
post #9 of 9 Old 09-05-2008, 10:21 AM
madrabbitt
madrabbitt's Avatar
tinted windows shouldnt affect the range on the RF ones, just the IR ones.
The fob on mine works from maybe 20 feet line of sight, and less if its in the building... although my kid manages to set off the panic button pretty much anywhere in the house, so it can vary.
You can only program the RF versions yourself IF you have two existing ones. Same with the sentry key, you need two current ones to add a third, or to replace one.
Installing HID's in stock housings is bad.
"When you see someone who needs help, help them. When you see someone who needs a hug, hug them... Help those who can't help themselves." -Sgt Andrew Tingwall, NMSP. End of watch 6-10-2009
madrabbitt is offline
Anyone have a pre-96 keyless entry remote? Mickey_D ZJ Grand Cherokee Forum 8 01-28-2009 09:26 AM
keyless entry remote peepmyjeep00 ZJ Grand Cherokee Forum 7 01-16-2008 11:41 PM
95 ZJ remote keyless entry/ help stowe115 ZJ Grand Cherokee Forum 5 11-06-2006 12:38 AM
95 ZJ remote keyless entry/ help stowe115 ZJ Grand Cherokee Forum 0 11-05-2006 07:03 PM
remote keyless entry automan25 ZJ Grand Cherokee Forum 3 01-01-2003 12:54 PM
