Remanufactured or junkyard durango swap? - JeepForum.com
post #1 of 17 Old 12-15-2012, 05:27 AM Thread Starter
sevenscrew
I am doing the box swap today, is it better to get a reman from autozone(durango 99, 4x4, v8, without plow) or get a junkyard durango one?
1997 Limited 5.2L - SOLD
2016 2DR JK
sevenscrew is offline
post #2 of 17 Old 12-15-2012, 05:43 AM Thread Starter
sevenscrew
bump, if i get reman, advanced auto cant get it until tuesday
2016 2DR JK
post #3 of 17 Old 12-15-2012, 08:28 AM
ozzy_2_me
1994 ZJ
what is a box swap?
ozzy_2_me is offline
post #4 of 17 Old 12-15-2012, 08:40 AM
98ZJLTD
I would go with the reman or see if I could get a brand new one. Just one less thing to worry about that way. Do they make a rebuild kit for it? That would probably be a pretty solid option as well if they do.
98 ZJ Limited- NP231 swap, IRO 4.5 inch Springs, Hydro Shocks, IRO adjustable double shear track bar, JKS quick discos 33x12.50 Kumho Road Venture MT on 15x8 D windows with 3.75 inch BS
My build thread-
98ZJLTD is offline
post #5 of 17 Old 12-15-2012, 09:53 AM
vegasZJ
I did a JY one lasted for a couple weeks then developed a ton of play. I adjusted it worked for a week or so then came back. Needless to say i have a remaned now. And its been good for months
When in doubt throttle out!
vegasZJ is offline
post #6 of 17 Old 12-15-2012, 11:07 AM
Dyn0mitemat
I've read all over when I was looking to do mine, and the remanufactured boxes just get new seals and they're back out the door in most cases. Either get a junkyard one or get a new one imo
09 Rubi 2dr:MetalCloak2.5", 37"MTZ's/Slabs, EVO Stff, ORFab Cage, Chromo's, Driveshafts etc
Dyn0mitemat is offline
post #7 of 17 Old 12-15-2012, 11:09 AM
ratmonkey
R.I.P.
ratmonkey's Avatar
there's two adjustments.
i'm using a junkyard dakota box right now actually. more turns lock to lock than i wanted, but it was cheap and lasted longer on 35's than my stock box did.
remanufactured boxes don't replace the sector shaft, there aren't replacements to my knowledge. if it's worn, it's junk. but many companies throw seals and o-rings at it and hope the customer gets past warranty time on it.
ratmonkey is offline
post #8 of 17 Old 12-15-2012, 03:50 PM
Snowfan2
Originally Posted by ozzy_2_me View Post
what is a box swap?
Steering box
Snowfan2 is offline
post #9 of 17 Old 12-15-2012, 04:22 PM Thread Starter
sevenscrew
Well I still have play with a JY box from a durango. But there's less.
2016 2DR JK
post #10 of 17 Old 12-15-2012, 06:15 PM
I dig AU
I'm using one of these:
Red-Head steering box reman process
Everything is nice and tight, no play. I think they can do custom ratios too. But they are pricey next to the parts house remans.
Good luck with yours.
I dig AU is offline
post #11 of 17 Old 12-15-2012, 06:38 PM Thread Starter
sevenscrew
I am replacing my weak oem SS, because my steering doesn't return to center that quick and I feel bumps in the road . Yes my linkage is parallel. Gonna get a aftermarket stabilizer and that should tighten it up a little
2016 2DR JK
post #12 of 17 Old 12-15-2012, 08:41 PM
PolkaPower
what is a box swap?
When you get a new GF.
PolkaPower is online now
post #13 of 17 Old 12-15-2012, 09:23 PM
xcaliber81
damit I was just gonna say that too lmao.
xcaliber81 is offline
post #14 of 17 Old 12-15-2012, 10:56 PM
Smokey1r
I didn't want to take any chances on remans so i rebuilt the box i acquired from the JY for the jeep i drive, its solid still, just the rest of the steering components are gone lol!!!
Smokey1r is offline
post #15 of 17 Old 12-16-2012, 09:38 AM Thread Starter
sevenscrew
how hard is it to rebuild? My junkyard durango box still has slop... Im replacing the SS today just to get rid of a little of the wandering, if any.
i dont know if it would be worth taking back to the junkyard (30 day warranty) because a new box is 500 bucks anyway and i cant afford that.
2016 2DR JK
