Relocating the wiper fluid resevior on a WJ - JeepForum.com
post #1 of 19 Old 09-22-2006, 10:20 PM Thread Starter
FearTheDentist
Just a suggestion...
FearTheDentist's Avatar
Well I finally got around to putting in a new windshield wiper fluid resevior today. For those unfamiliar with this issue with WJ's, the wiper fluid resevior is in the driver side wheel well such that he first time you get some good flex with your sway bar disconnected you're going to mash it. I tried several different ways, and decided that there unfortuately is no good place under the hood to relocate it to.
I noticed that the resevior from a ZJ is not such a goofy irregular shape, so I bought one off ebay ($5 including both pumps and fluid level sensor, can't beat that.) Looking under the hood, I noticed there's a nice space next to the brake fluid resevior, but there's a piece of the vacuum system in the way (Pic 1). So, I relocated the mount as far back in the corner as I could drill a hole (Pic 2). To relocate the thing without putting tension on the pre-formed vacuum lines I flipped them over. This them crossed them, so unplug one, uncross it, and plug it back in (notice how they now fit nicely behind the brake fluid resevior). Now, when I tried in the resevior if was an almost perfect fit, and one of the mounts even lined up with an existing bolt (you have to jimmy it around a little bit to get it to fit, but it's not hard). The bolt was a ground for several wires so I relocated these to another nearby bolt to be on the safe side. I (carefully) cut open the wire harness that included the wires to the pumps and fluid level sensor and seperated these out, then taped the remaining ones back up. I bolted in the resevior using the one existing bolt, then drilled a hole for the other mount and drove in a self-tapping bolt. Everything lined up perfectly, so I pulled the resevior back out, spliced the existing wires to the new pumps and sensor, and bolted it back in. Fits perfectly (level and doesn't interfere w\ closing the hood) and looks like it came from the factory that way. I have a K&N FIPK II, but I think this wouid work with a factory airbox too. Here's some pics:
'04 4.7 WJ 6" Clayton's, full width 60\14b, 37" Nitto mud grapplers, lots of bits and pieces
FearTheDentist is offline
post #2 of 19 Old 09-23-2006, 12:43 AM
CunningLinguist
Good job. How long were you without one? A long time if i remember!
Mine is mashed too, i will follow your guidelines.
Just Empty Every Pocket!
02 WJ Limited V8, KRC Engine, RAM45 545RFE Trans, Clayton Long Arm.
03 WJ Laredo I6, IRO 4", 31x11.5 LTB
Originally Posted by Dope Schemes
By all means enjoy Halo 2.5 but for those with cerebral development beyond that of a spider monkey, pick up Bioshock, you won't regret it.
CunningLinguist is offline
post #3 of 19 Old 09-23-2006, 12:53 AM
AgitatedPancake
I havent had one for....a year and some time? Man there are sometimes I miss it. Windshield wipers dont do well with de-icer.
To contact me, email
01 WJ 5 Speed Claytons LA's, 36" Iroks, 35 spline 9" rear, Custom Ruffstuff 60-9" front axle.
Build Thread:
AgitatedPancake is offline
post #4 of 19 Old 09-23-2006, 01:13 AM Thread Starter
FearTheDentist
Since march '05 for me. Things get really dusty and grimy here...
post #5 of 19 Old 09-23-2006, 02:07 AM
jeep_on
Some one care to explane how a sway bar are mash the resevior?
2006 Dodge RAM Laramie w/ 5.9L I6
2010 Volkswagen Jetta w/ TDI 2.0L I4
Waiting on a 2013 RHD JK Unlimited
Originally Posted by PM Thor View Post
Wait, you can't cross creeks up there? What the Hell is up with these Canadians?
jeep_on is offline
post #6 of 19 Old 09-23-2006, 02:42 AM
AgitatedPancake
on the WJ the wiper fluid reservoir is in the upper front of the left fenderwell. If you disconect your swaybar, and flex your truck out with larger tires, the tires will catch the pumps on the reservoir and tear them out.
Build Thread:
post #7 of 19 Old 09-23-2006, 07:45 AM
sailingnut
sailingnut's Avatar
Nice write up
Havent busted mine yet
But when I go bigger Ill rember.
2000 WJ IL6
2.5" BB Jks Quick Discos
Matalic green perl
My first jeep
thanks Jim ;)
Colorado Jeep Club Member
sailingnut is offline
post #8 of 19 Old 09-23-2006, 04:32 PM Thread Starter
FearTheDentist
In my case it wasn't just the pumps, it was the whole shebang. The Thunderchickens I used to run (briefly) had really big side lugs- one of 'em caught the resevoir and ripped the whole thing off, then I promptly ran it over. I would have cursed but I was laughing too hard....
Now that I've mentioned my old Thornbirds let's see how long it takes Hunter to chime in- he's still mad that I wouldn't let him have them
post #9 of 19 Old 09-23-2006, 05:49 PM
10achik
I ate what?
10achik's Avatar
If only you had done this before I went to all the trouble I did. Very nice install, I like your's better.
Ken
99 GC Limited - 4.7L HO V8, 6.5" IRO HC LA lift, F&R D44s locked & trussed, 242HD, IRO TC Skid, KMA Bumper, 35's
2006 Saturn Redline -2.0L Eaton supercharged I4, GMPP Stage 2, Custom Tune, AEM CAI, Ebiach Pro Kit w/ swaybars, EVO Ventus V12s (13.76 @ 103.85)
2006 Pontiac G6 GTP
2012 Nissan Juke - (hers)
2000 SV650 - naked, integrated tail light, sliders, corbin, pilot roads, RK chain & sprokets, D&D full exhaust, FactoryPro Stage I jet kit, +4 Ignition Advancer, Barnett race clutch
2006 Triumph America 900 - Full Dresser
January 2009 Grand Cherokee of the Month (GCOTM)
10achik is offline
post #10 of 19 Old 09-23-2006, 06:33 PM
Blake
Redefining body roll
Blake's Avatar
What did you do with yours?
1991 Lexus LS400
Daily Beater
2006 Ford F250 Larait
6.0 Powerstroke | 4x4 | Crew Cab
Blake is offline
post #11 of 19 Old 09-23-2006, 07:28 PM
10achik
I ate what?
10achik's Avatar
It's all here:
http://www.jeepforum.com/forum/f13/windshield-wiper-reservoir-302921/
I basically used the same bottle but put it under the K&N and sealed the original hole and added another one because it had to sit sideway's. His looks like a professional install, whereas mine kinda looks well.....
Ken
2006 Pontiac G6 GTP
10achik is offline
post #12 of 19 Old 09-23-2006, 07:39 PM
rrubio
rrubio's Avatar
I have been without one for about two years at least now myself.I have a ZJ bottle in my garage just begging to be installed.
rrubio is offline
post #13 of 19 Old 01-03-2007, 01:41 PM
mdoffroad
I have a question to the original poster, WHERE is your charcoal canister??? where you put yoru bottle (GREAT spot) mine (99) has a charcoal emmsions canister, can ya help us out?
Matt
mdoffroad is offline
post #14 of 19 Old 01-03-2007, 01:45 PM
ArloGuthroJeep
Mr. Hyde!
ArloGuthroJeep's Avatar
His canister is probably under his back bumper.
'14 WK2 Limited w/5.7L, ORAI, & Tow Package
ArloGuthroJeep is offline
post #15 of 19 Old 01-03-2007, 01:47 PM
ArloGuthroJeep
Mr. Hyde!
Here is how I did it - nearly identical, just further forward.
http://www.jeepforum.com/forum/f13/zj-washer-fluid-reservoir-place-wj-s-321148/
Windshield Wiper Fluid Freezing SSF556 WK Grand Cherokee & XK Commander Forum 1 12-10-2008 08:57 PM
Rear Wiper Fluid Question JustSomeDude ZJ Grand Cherokee Forum 13 12-18-2007 06:20 AM
mixing wiper fluid??? CMARJEEP ZJ Grand Cherokee Forum 4 12-08-2007 11:35 PM
Wiper Fluid Dispenser Problems venterminator ZJ Grand Cherokee Forum 2 02-23-2007 02:36 PM
Relocating washer fluid resevoir in an '04 WJ FearTheDentist ZJ Grand Cherokee Forum 4 05-02-2005 07:50 PM
