Releasing R12a From A/C System - JeepForum.com
post #1 of 3 Old 07-11-2009, 12:38 AM Thread Starter
eboyer7
Hi. I recharged my A/C system a few weeks ago, but I overcharged it slightly (I charged it up to 45 psi, which is the border line between acceptable and too high, according to Duracool). So I have three questions: Will this cause any problems if I keep it at this high of a pressure? And, if I do have to lower the pressure can I just release some of the R12a that I used for the recharge into a paper towel or something and throw that out? The system was completely empty before the recharge, so there's only R12a in there (no R12 or R134a). And, the can of R12a says it's a natural coolant that isn't ozone-depleting, so I'm guessing it'd be alright to release it myself? Also, what kind of problems would occur if the system had been overcharged any further, like 60 or 70 psi?
eboyer7 is offline
post #2 of 3 Old 07-11-2009, 01:43 AM
WiCkeDuDe
WiCkeDuDe's Avatar
Overcharging is hard on the compressor and can cause leaks in the system more easily. Basically is just harder on the system and can lead to a less efficent cooling status. At 45 pounds your right in the middle. This should not cause an issue but you could release some pressure. I think my jeep was right around 25-30 pounds at max ac.
WiCkeDuDe is offline
post #3 of 3 Old 07-11-2009, 07:11 AM
sdowney717
it is a mix of propane and iso butane. People release this into the air everytime they light a gas grill.
sdowney717 is offline
WJ 242 TC not releasing from 4x4 mode EisBlade ZJ Grand Cherokee Forum 7 12-19-2009 03:37 PM
2002 WJ bump after releasing brakes. bonavd ZJ Grand Cherokee Forum 6 08-03-2009 08:53 PM
Thunk when releasing gas pedal samsdad ZJ Grand Cherokee Forum 14 03-23-2007 08:28 PM
Noise when releasing my brake, help! will_b ZJ Grand Cherokee Forum 5 02-13-2007 08:50 PM
clunk when releasing gas pedal laphan ZJ Grand Cherokee Forum 18 10-07-2005 03:30 PM
