Relay failure? (electrical problem) - JeepForum.com
post #1 of 5 Old 11-20-2006, 01:23 PM Thread Starter
retrovoice
I have a 99 GC with an electrical problem that started three days ago.
On three occasions when I turned off the ignition (after driving) the power to the interior electrical system failed. It wasn't completely dead. There was a constant clicking sound that seemed to come from under the dash occuring around 2-4 Hz. The dials on the instrument cluster were moving randomly. The light under the driverside dash was dim and flickering at the same frequency of the clicking sound.
Except for the random movement of the gauges and the clicking sound, the vehicle behaved as if there was no electrical power. Actuating the RF remote had no effect either.
This first happened when I arrived at a local Target store. I went inside to shop and when I came back out 20 minutes later, everything was back to normal. I started the Jeep and drove home. Everything worked fine. The clock on the radio did reset though, consistent with loss of power.
Any help is appreciated.
retrovoice is offline
post #2 of 5 Old 11-20-2006, 04:48 PM
MtnbikerWJ
MtnbikerWJ's Avatar
I would start by checking for loose or corroded battery connections.
04' WJ Laredo 4.0L 4x4
245/75-16 GY MTR's
Rusty's 2" BB
ARB Bull Bar with Piaa 520 drivings, no winch yet though
Kenwood Headunit, Kenwood Sirius Reciever, RF Punch p2002 Amp, RF Punch 10" Sub enclosure
Hypertech power programmer
K&N 77 series FIPK
Flowmaster 50 SUV
Magnaflow Cat
next gears and lsd's and OME coils
Colorado Jeep Club Member #14
White Jeep Club Member #114
MtnbikerWJ is offline
post #3 of 5 Old 11-20-2006, 09:44 PM Thread Starter
retrovoice
The battery connections are clean (no corrosion) and the cables are solidly attached. When the problem's not occuring, the battery power is strong, starts the car without problem, and everything functions fine.
post #4 of 5 Old 11-21-2006, 08:28 PM
1 Long CJ
I had something similar going on when one of my taillight sockets shorted out. I think it got wet. Just check if all your lights are working.
Life is short. Play hard.
1979 CJ5, 1982 CJ8, 2004 WJ, 2006 LJ Rubicon
1 Long CJ is offline
post #5 of 5 Old 11-22-2006, 09:43 AM Thread Starter
retrovoice
Thank you for the suggestion. I'll check out the lights. It's been 4 days since the problem last occured. If it was due to some moisture causing a short, then maybe the problem has, for the moment, cured itself.
95 ZJ Electrical problem Rear Lamp Failure subliminal ZJ Grand Cherokee Forum 12 07-14-2013 06:28 PM
06 Commander has intermittent electrical failure..any suggestions where to start pardo_1974 WK Grand Cherokee & XK Commander Forum 4 12-04-2009 10:01 AM
Intermittent Electrical(?) Failure rupped ZJ Grand Cherokee Forum 1 11-25-2009 10:31 AM
[Almost] Total Electrical Failure jeffjs WK Grand Cherokee & XK Commander Forum 5 01-08-2009 09:44 AM
Electrical problem/relay issue hemiguy ZJ Grand Cherokee Forum 0 08-12-2008 08:25 PM
