Hi,
planing to freshen up my girlfriend's ZJ wheels. At first i was going to strip the clear cote and start everything from the scratch. But as it's going to be a temporary solution and has to last not more than 2 winters then maybe i just have to sand down the loose lacquer and spray on couple of coats of wheel paint and then couple of coats of clear lacquer. I will not remove the tires from the wheels, only mask them. Should i use any primers under the paint (couse new paint is going to be solid color)? And should i still use chemical stripper to take everything completely down? Any suggestons?
Thanks guys.
Thanks guys.
