Received death wobble lol Fixing... - JeepForum.com
post #1 of 15 Old 09-19-2013, 10:45 AM Thread Starter
lawsonej
Im not asking for help.....yet...This thread is basically an update for people who use the search button in the future to fix thier death wobble problems. Ive been missing a sway bar link for about two years now and never have had the death wobble. I put in a steering stabilizer i had here at the house for a while and i come to find out that the dw appeared over night. M track bar moves a little and needs to be replaced, but ill start with this missing sway bar link! seems like the best thing to do.
lawsonej is offline
post #2 of 15 Old 09-19-2013, 10:57 AM
98ZJLTD
I would fix the track bar right away as well, if there play in there it's gonna be factor in your death wobble without question.
98 ZJ Limited- NP231 swap, IRO 4.5 inch Springs, Hydro Shocks, IRO adjustable double shear track bar, JKS quick discos 33x12.50 Kumho Road Venture MT on 15x8 D windows with 3.75 inch BS
My build thread-
98ZJLTD is offline
post #3 of 15 Old 10-19-2013, 01:39 PM
docjones
My death wobble was helped greatly by replacing the track bar, a bit more benefit came from replacing the steering stabilizer and it completely went away with new front shocks. My front shocks didn't look bad and neither were leaking but after I compressed the driver's side shock to remove it the damn thing never extended again so it was completely shot! I guess I lucked out by fixing my DW with simple -to - replace parts. My Jeeps' steering feels more stable now than it ever has. Good luck
docjones is offline
post #4 of 15 Old 10-19-2013, 03:46 PM
WhiteOut
WhiteOut's Avatar
Steering stabilizer won't solve death wobble, nor can it cause it.
WhiteOut is offline
post #5 of 15 Old 10-20-2013, 01:47 AM
98ZJLTD
^^^^ This. I went rounds and rounds throwing all kinds of stuff at mine trying to figure out my death wobble. After having a local 4 wheel shop look at it i was told to replace my front lower shock bushings, steering stabilizer, and re torque everything, I did all that and still had death wobble. After taking it back to them, they said they could fix it with an aluminum track bar bushing for $160 they installed said bushing, and a month and a half later, my track bar broke while I was driving due to this bushing they fabricated to "fix" my DW. So I spent another $40 ordering new parts from IRO and made sure the track bar was dialed in and the front axle was dead nuts centered and I havnt had an issue since.
Moral of the story... if you know you have a track bar issue fix it because it will definitely be a contributing factor to your problem.
My build thread-
98ZJLTD is offline
post #6 of 15 Old 10-21-2013, 08:21 AM Thread Starter
lawsonej
Okay folks, Sorry i didnt get back to the solution. Im putting the track bar on today, but I did put on (some of the parts ive had for a while) a new drag link bar, sway bar links, and stabilizer bar. Then I had it aligned and the death wobble went away. I did pay for free alignment for a year about 6 months ago so i have a few months to bring it back. It did solve the DW for now, there is basically not even a slight wave of the suspension while hitting bumps at any speed but i will be putting in that track bar since the originally one is shot and has play. To be honest, i have no clue how it still doesnt have the wobble now...Thanks for the tips
edit: in my original post, i just thought it was weird that i had never got the full death wobble , only slight shaking in my suspension before adding that steering stabilizer....agreed, it makes no sense. Maybe something else gave. I Probably just knocked it out of alignment while putting on the part.
lawsonej is offline
post #7 of 15 Old 10-21-2013, 08:59 AM
JohnnyZJ
theres always a common ingredient in deathwobble....... multiple worn out parts in the front end................ usually trackbar.
the way jeep suspension is design DW will always be just around the corner; thats why they have steering stabilizers. their job is literally to mask DW. but if you have to many worn out parts in the front, eventually that worn out 'play' will send your jeep in DW mode and make you crap your pants.
Death wobble is the oscillating of your front axles moving back and forth at an alarming rate due to hitting a bump etc. basically the axle is moving independantly of the rest of the jeep, hence it shakes. a steering stabilizer will not fix this, because the Steering stabilizer cannot keep the axle inline with the jeep. something that keeps the axle aligned with the jeep is bad; thats leads to this -->
1: track bar almost all the time
2: control arm bushings
3: balljoints/hubs/Tierod ends or a combination of all these.
4: shocks, sway bars, alignments: don't caus issue.
typically a DW prone jeep has worn out everything, so it doesn't take much from any part to set it off. and sometimes...... sometimes...... your jeep just sucks and will go DW berserk because it wants too.
there you go; Death Wobble 101.
07' JKUR rollin on 35s
JohnnyZJ is offline
post #8 of 15 Old 10-21-2013, 09:52 AM Thread Starter
lawsonej
Sounds like speaking from experience lol
lawsonej is offline
post #9 of 15 Old 10-21-2013, 10:36 AM
PolkaPower
The first time I put a lift on I was so excited that I forgot to tighten down the track bar. Boy that was a fun first test drive. I thought there was an earth quake.
PolkaPower is online now
post #10 of 15 Old 10-21-2013, 12:54 PM
JohnnyZJ
actually i've been farting around with jeeps, ZJs for about 7 years now, every one of them lifted, and i've never actually experienced DW. so either i'm really lucky, or i figured out how to avert it
JohnnyZJ is offline
post #11 of 15 Old 10-21-2013, 04:26 PM
Fookn4x4
Can someone post a pic of the track bar? This is my first Jeep and I've been having problems with this as well. No lift here though.
Fookn4x4 is offline
post #12 of 15 Old 10-21-2013, 04:32 PM
PolkaPower
post #13 of 15 Old 10-21-2013, 04:32 PM
98ZJLTD
Here you go
My build thread-
98ZJLTD is offline
post #14 of 15 Old 10-21-2013, 04:33 PM
98ZJLTD
Ya beat me to it polka lol
My build thread-
98ZJLTD is offline
post #15 of 15 Old 10-21-2013, 04:43 PM
PolkaPower
Only because I was too lazy to post the pic.
