Rear Wiper problem - JeepForum.com
post #1 of 5 Old 12-17-2002, 06:16 PM Thread Starter
Black96ZJ
Rear Wiper problem
The rear window wiper on my 96 Zj has stuck, "all the way to the left" its about 3 inches from the base of the window ( where it usual stops, and starts going back the other way). The squirter for fluid still works though. one of my friends said that it was probably a fuse that has blown. i looked in the engine compartment and couldnt find any fueses for this. is there another fuse box somewhere else on the car, if so can someone tell me where it is. Also, if it is not that, does anyone have an idea as to what the problem could be. thanks very much
- Daniel
Black96ZJ is offline
post #2 of 5 Old 12-17-2002, 06:45 PM
Camster
Camster's Avatar
i have the same problem with mine. i've been told it's a faulty motor in some ZJ's and if you take it to the dealership they will replace it for free. i haven't acctually gone and gotten it fixed yet though. i'd say it's worth a try before you sweat too much. good luck!
Cameron
Camster is offline
post #3 of 5 Old 12-18-2002, 03:35 PM
ZJGuido
Junior Member
ZJGuido's Avatar
rear wiper problem
there's another fuse box located on the passenger side of the car.Its under the dashboard, to the right, on the kick panel. There you can find fuses and relays. u can check there for the fuse.
1997 Stone White ZJ Limited w/4.0
1989 White XJ Laredo w/4.0
My ZJ Limited
ZJGuido is offline
post #4 of 5 Old 12-19-2002, 07:36 PM
gcl97
Turn wiper switch ON, then try to open the liftgate, do the wiper goes into its original position?
gcl97 is offline
post #5 of 5 Old 12-21-2002, 01:23 PM
MJR
MJR's Avatar
1988
Pretty common for the rear wiper motor to go out. You could turn it on and help it by hand.
"Got Groceries"
88 Jeep Wagoneer
MJR is offline
zj rear wiper problem zjilla ZJ Grand Cherokee Forum 5 02-03-2009 09:58 PM
Rear Wiper Problem TORMULA ZJ Grand Cherokee Forum 6 12-26-2007 03:13 AM
98 ZJ Rear Wiper problem brianlward ZJ Grand Cherokee Forum 2 01-18-2007 04:19 PM
Rear Wiper Problem CEaston140001 ZJ Grand Cherokee Forum 3 12-08-2006 04:50 PM
Yet another rear wiper problem Bloodbath ZJ Grand Cherokee Forum 3 07-12-2006 07:39 PM
