Rear wiper motor misaligned - Page 2 - JeepForum.com
post #16 of 17 Old 12-08-2011, 07:31 AM
KoreaZJ
1994 ZJ
Originally Posted by jnowak View Post
Take the wiper arm off of the motor. turn the motor on than off. that will put the motor in its bottom position. reinstall the wiper arm in the bottom(like when its off) position. should put the wiper back in time.
As long as the motor is running/reversing normally. Otherwise the relay or contacts are messed up.
The worm gear drives the yellow gear until the brass plate makes/breaks contact toggling the relay which reverses polarity on the motor to reverse directions. The registration is done by the position of the brass contacts, not by the relation between the two gears.
KoreaZJ is offline
post #17 of 17 Old 12-09-2011, 08:27 AM Thread Starter
BlueDevil
^that.
And I strongly suspect that the yellow gear (which I keep calling white, God only know why ) is not in the correct position in respect to the worm gear. It was taken off, and then returned in different position, so the brass plate is not @ the angle it originally was.
I'm trying to find images on the web of the wiper motor open, to see if I can assume the correct gear position. I presume they're all the same when they come from factory, meaning I could get lucky with just one good picture... Anyone? Bueller?
Beauty is in the eye of the beer holder
* 1994 ZJ (by VIN) with a 1995 engine (PO knows why)
BlueDevil is offline
rear wiper motor help KillaJeep4569 ZJ Grand Cherokee Forum 10 11-07-2011 05:21 PM
rear wiper motor help KillaJeep4569 ZJ Grand Cherokee Forum 0 09-26-2011 04:35 PM
rear wiper motor Maciej ZJ Grand Cherokee Forum 12 02-17-2006 09:56 AM
rear wiper motor alpine ZJ Grand Cherokee Forum 3 12-17-2003 02:00 AM
Need Rear Wiper Motor evalasek ZJ Grand Cherokee Forum 3 04-04-2002 09:04 AM
