Rear wiper motor misaligned - JeepForum.com
post #1 of 17 Old 12-08-2011, 12:55 AM Thread Starter
BlueDevil
PO did a good job at taking the rear wiper motor out to clean it before it sieed, I'll give him that. But he did put the white gear in the wrong way.
I myeslf, before trying to tear it apart & see what's wrong, have read a lot and have found out that it's a really important thing to pay attention EXACTLY where the white gear was, how much it was turned to one side or the other, and to put it all back in the same way. And so I did.
But when I turn it on, it goes like 1 or 2" up, then it stops, obviously waiting for the delay, and then it goes down, over the licence plate, and locks itself pointing towards the exhaust pipe. Obviously, the great white gear is turned the wrong way.
Question is, how do I correct that? I can't go opening the motor, displacing the gear by 1 tooth, close it all, mount, try, and then repeat the process untill it is right (which might easily be like 50 times, no exaggerating). Any other way?
Beauty is in the eye of the beer holder
* 1994 ZJ (by VIN) with a 1995 engine (PO knows why)
BlueDevil is offline
post #2 of 17 Old 12-08-2011, 01:09 AM
bigbill888
are the wires crossed?
96 ZJ Laredo, 4.0, 242, 230K
95 ZJ Limited, 4.0, 242, 140K
98 XJ Sport, 4.0, 231, 140K
All work well
bigbill888 is offline
post #3 of 17 Old 12-08-2011, 01:09 AM
zander21510
pull a motor from the junkyard. chances are it will work otherwise I can't think of another way.
zander21510 is offline
post #4 of 17 Old 12-08-2011, 01:15 AM Thread Starter
BlueDevil
Bigbill, it's not the wires, it's the big gear that has brass on it for contact. If you take apart the motor and remove that gera but don't return it in the same way it was (regarding to the casing of the motor), it won't rotate "from point A to point B and back" as it should, but the "point A" and "point B" would be on different places from where they should be.
Zander: I wish I could. But back here there virtually ain't any Jeeps on JYs. Literally ANY, no model, no year, no condition - inexistant.
post #5 of 17 Old 12-08-2011, 01:57 AM
KoreaZJ
1994 ZJ
Isn't the motor shaft splined where you can just pull the arm, rotate to the correct position, then reinstall it?
KoreaZJ is offline
post #6 of 17 Old 12-08-2011, 02:23 AM
SAR-Swimmer
I've never taken one apart, but there must be some sort of contact that prevents the wiper from going down as far as it's going now, and stopping it at the "Park" position. If you can figure out how that system works you should have your bottom limit. I'd be tempted to remove the motor, and since you know that the gear IS the wrong way, rotate the gear the other way, and determine the new arc pattern resulting by moving the stud mount that goes to the wiper arm, either by hand, or jumpering the motor with a 12 volt source. If you put a tooth-pick or paper clip on the stud, it should help you visualize the new sweep arc. (90-120* ?, with 0*being the "park" position). I'd think you should be able to get close on the bench, saving removing and replacing the motor in the jeep a bunch of times, as you move the gear and check.
I'm just guessing here, but hopefully, this will work for you. Good luck
SAR-Swimmer is online now
post #7 of 17 Old 12-08-2011, 02:41 AM
SAR-Swimmer
You just might be right KoreaZJ,but if you reposition the arm,(from the bottom of the sweep arc), currently past where the wiper should be, to the correct
"Park" position, have you not lost that much of the arc? ie you would not have
full sweep of the wiper at the upper end?
post #8 of 17 Old 12-08-2011, 03:20 AM
KoreaZJ
1994 ZJ
Sounds like the shaft has proper swing, but the arm is installed rotated to far CW.
Seems like you'd let the motor come to rest (off position), then install the arm where it belongs.
KoreaZJ is offline
post #9 of 17 Old 12-08-2011, 05:57 AM
merlot2twisty
Of course, you could always find the position of the gear by trial and error. Time consuming, but it'd work.
merlot2twisty is offline
post #10 of 17 Old 12-08-2011, 06:45 AM
KoreaZJ
1994 ZJ
Splines
KoreaZJ is offline
post #11 of 17 Old 12-08-2011, 06:54 AM
jnowak
Take the wiper arm off of the motor. turn the motor on than off. that will put the motor in its bottom position. reinstall the wiper arm in the bottom(like when its off) position. should put the wiper back in time.
jnowak is offline
post #12 of 17 Old 12-08-2011, 06:54 AM Thread Starter
BlueDevil
OK, that's the motor with its casing. If you open the casing, on the other end of the shaft you'll find this (see attached picture). Now, it's necessary to take the big white (yellow) gear out (it takes the shaft with it) for the interior of the tunnel where the shaft goes to be cleaned. And when you return it, you can see there's a lot of possible ways to put it. What I'm saying that PO did not take care of which way was the big white gear in relation to the casing, and he didn't put it in the right way. So not only can a wiper arm go to sleep and stop points that are off, but it can also get stuck (when the brass plate rotates too much & fells out of the tiny contacts it touches when everything is back together). Or it can do less than necessary way in one direction, but too much in the other, and by doing so it keeps shifting it's "endpoints" every time it works.
post #13 of 17 Old 12-08-2011, 07:16 AM
KJK
Originally Posted by BlueDevil View Post
PO did a good job at taking the rear wiper motor out to clean it before it siezed,...
Apparently he didn't...
5.9 ZJ SCT tuned PCM/ KJK CAI/ Thorley headers with 3" Magnaflow cat and muffler/ Modded kegger/ TransGo shift kit/ Vanco brake kit/ Braided steel brake lines/ Mopar cupholder insert!
KJK is offline
post #14 of 17 Old 12-08-2011, 07:18 AM Thread Starter
BlueDevil
Tru dat
However, the motor is still turning, so it survived somehow.
Looks like it'll be trial-and-error, a looooong testing until I fix it. Because ordering a used one from e-bay, with transport & customs, is waaaay too much :/
post #15 of 17 Old 12-08-2011, 07:24 AM
KJK
I feel your pain. I've dealt with a few but have no easy hints. It's amazing how something so seemingly simple as a wiper motor can cause so many headaches when it goes wrong!
KJK is offline
rear wiper motor help KillaJeep4569 ZJ Grand Cherokee Forum 10 11-07-2011 05:21 PM
rear wiper motor help KillaJeep4569 ZJ Grand Cherokee Forum 0 09-26-2011 04:35 PM
rear wiper motor Maciej ZJ Grand Cherokee Forum 12 02-17-2006 09:56 AM
rear wiper motor alpine ZJ Grand Cherokee Forum 3 12-17-2003 02:00 AM
Need Rear Wiper Motor evalasek ZJ Grand Cherokee Forum 3 04-04-2002 09:04 AM
