rear wiper motor - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > rear wiper motor
Zone Offroad Body and Suspension Lift Kits, Brackets, DiscJeep Wrangler Framless, Bowless, Trektops 92-95 YJ, 97-06 Baseline 4x4 Lifetime Warranty 4340 Chromoly Axle Shaft Ki
Unread 12-27-2005, 10:27 AM   #1
Maciej
rear wiper motor
My rear wiper is not working. Probably because of dust in axle. Maybe someone has removed rear wiper motor and made some repair? I will be glad to receive some tips.
________________
96 ZJ 5,2
2,5'' BB, DTs3000, 31 BFG MT
LPG
[URL="http://community.webshots.com/photo/550704770/2859657980076956703LOySOe#"]http://community.webshots.com/photo/550704770/2859657980076956703LOySOe#[/URL]
Maciej is offline   Reply With Quote Quick reply to this message
Unread 12-27-2005, 10:35 AM   #2
Phil Gerard
Former Mod
Phil Gerard's Avatar
Here ya go:
http://www.nagca.com/grandtech/rearwiperrepair.htm
Phil
'95 ZJ Ltd. White 4.0L
TW DC DS; ARB Bull Bar, F&R Air Lockers; Superior Axles; Warn Winch; 4.56 gears; ACOS, Addco F&R Sw Bar, JKS Discos, Rr Track Bar & Nerfs, 249>242 Swap, Stillen rotors+Kolak pads, 3 pc. Armor, RE 4.5 Kit + 2.5"BB, Adj. UCAs&LCAs, OME SS, Bilstein 5150s, 15x8 AR Diamond Backs, 33 Truxus MTs, K&N FIPK, RE 62mm TB, Perf. Distr. 4.0L Kit, Exhaust: 2.5" Kolak exhaust FM 70: Optima Yellow, Mean Grn Alt., PIAA 520s, 540s, Kevins Rack, & TB Conversion
Phil Gerard is offline   Reply With Quote Quick reply to this message
Unread 12-29-2005, 07:38 AM   #3
Maciej
many thanks!!!
________________
96 ZJ 5,2
LPG
Unread 12-29-2005, 09:54 PM   #4
kentman
2006 XK Commander
I too thought that my motor was not working once a long time ago. In actuality, my rear hatch does not close fully on every fourth or fifth slam. The door seems shut, but it is not fully closed. Every time I use the gate, I turn the wiper on to see if it is fully shut. If it is shut correctly, then the wiper will work. If not, then it will not work. I think that the previous owner damaged the hinge by over-stressing it. The hinge alignment is just such that it does not close perfectly every time.
'06 XK Limited, 5.7L, QD II, Black, 148K
'02 WJ Overland, 4.7L HO, QD, Inferno Red, 113K
kentman is offline   Reply With Quote Quick reply to this message
Unread 01-03-2006, 10:14 AM   #5
Maciej
I have done it! It was very hard to remove wiper shaft. I thought it will be not possible and using hammer was so. I used vise BUT very carefully. Now my wiper works very fast and like new one! I think important is to repair before wiper stops forever. My stopped. If anyone needs help I will!
________________
96 ZJ 5,2
LPG
Unread 01-03-2006, 02:08 PM   #6
bobiam
These things are troublesome.......... There is an adjustment on the unit that can fine tune it (with the plastic off the inside of the hatch), but if like mine it was a waste of time and I had to replace it. The dealer had it in stock (re-mfg) and said that it's a common replacement. The shaft on mine was fine. It was internal.
Bob
bobiam is offline   Reply With Quote Quick reply to this message
Unread 01-05-2006, 10:58 PM   #7
canadia_driver
i have an extra motor if anyone needs, PM if u want it
canadia_driver is offline   Reply With Quote Quick reply to this message
Unread 02-13-2006, 01:02 PM   #8
acitydweller
i May need one... going to try reconditioning mine first...
finger crossed.
btw, thanks for the reference. Heaps of help!
acitydweller is offline   Reply With Quote Quick reply to this message
Unread 02-13-2006, 01:10 PM   #9
canadia_driver
sorry too late already sold it, normally u can get the old one working tho, ive done 3 motors and the only reason i had to buy a new one was because i was stupid and hit the shaft with a hammer and the nut wouldnt fit on afterwards
Unread 02-14-2006, 06:52 AM   #10
acitydweller
ok, ill have a go at fixing this one. it works sometimes...not the times you need it
i also noticed that i dont ahve the end cap / cover to the base of the rear wiper. is this something i can buy separately or do i need a whole wiperarm assembly?
thanks
Unread 02-16-2006, 11:12 AM   #11
acitydweller
Hey, Can anyone tell me exactly where on the trunk lid are these hidden screws? knowing me and my heavy hand, i may end up tearing out the lid cover.
thanks in advance.
Unread 02-16-2006, 12:21 PM   #12
canadia_driver
there are two screw behind the carpet near the bottom left and right corners, if u feel around you should feel the cuts in the carpet where teh screws are
Unread 02-17-2006, 10:56 AM   #13
acitydweller
Awesome. Youve been a great help Canadia driver.
thanks!
