Rear window went pop and seperated from the regulator. - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > Rear window went pop and seperated from the regulator.
SPARTAN LOCKERS are on sale BIG TIME at ROCKRIDGE 4WD!TJ Wrangler 4" Rough Country Suspension Lift Kits in Engo winches available at www.rockridge4wd.com! Free shipp
Unread 01-07-2015, 08:32 PM   #1
xcaliber81
1994 ZJ
Whats the likely hood its a simple fix and the black strip is still in 1 piece? I wont get to look at it till tomorrow im curious if its happened to someone else.
xcaliber81 is offline   Reply With Quote Quick reply to this message
Unread 01-07-2015, 09:26 PM   #2
coralman
I can wish can't I?
coralman's Avatar
If you are talking about the bracket on the glass, unless its rusted away pretty good. The adhesive turns loose. There is a special adhesive the glass shops have but I've read on here that people have used jb weld and others .
http://www.jeepforum.com/forum/f13/c...-faqs-2863665/
coralman is offline   Reply With Quote Quick reply to this message
Unread 01-07-2015, 09:32 PM   #3
xcaliber81
1994 ZJ
Is that usually what happens is the black strip comes loose? I just swapped out the motor and regulator so I know its not rusted, also I can hear the regulator moving separately from the window. The window is being held up be the regulator until tomorrow that is.
Unread 01-07-2015, 10:56 PM   #4
kachink
Another point of failure is the plastic bushings that ride in the channels in the regulator break. Nobody sells just the bushings, but there's a thread on here somewhere about making them that worked well for me.
kachink is offline   Reply With Quote Quick reply to this message
Unread 01-07-2015, 11:17 PM   #5
xcaliber81
1994 ZJ
There's plenty in the junk yard near my house in that case.
Unread 01-08-2015, 01:35 AM   #6
siguy
plenty of jeeps in the yards to pop up a new regulator... of try ebay
siguy is offline   Reply With Quote Quick reply to this message
Unread 01-08-2015, 02:52 PM   #7
Roadtripguy
Several years ago I had a driver's side window separate from the track on a VERY cold day when the window was frozen to the rubber weather strip. I fixed it with some gorilla glue, and never had a problem with it since. I smoke, so that window goes up and down a LOT.
Roadtripguy is offline   Reply With Quote Quick reply to this message
