Rear Wheel Bearing replacement - JeepForum.com
post #1 of 17 Old 06-01-2007, 08:46 PM Thread Starter
scudman
2000 FSJ Cherokee
I have a grinding noise coming from the drivers side rear wheel. I am thinking wheel bearing gone bad. How hard is it to change out. I have basic tools. What would I need special and about how long should it take.
2000 Grand Cherokee Laredo
4.0
scudman is offline
post #2 of 17 Old 06-02-2007, 12:08 PM
SJZ
Victim of Hope & Change
SJZ's Avatar
Location: . . . . . . . . . . . . . . . A shining city upon a hill
4.0
It's possible that the parking brake shoe/hardware, located in the "tophat" style rear rotor could be causing the noise. They're known for rusting out .
-Steve
"Those who hammer their guns into plows, will plow for those who do not." -Thomas Jefferson
___________________________________________
'98 ZJ Laredo 5.2 Selec-Trac (249 to 242 swap)
'05 KJ Limited 3.7 Selec-Trac
'94 ZJ Limited 5.2 Q-Trac- sold, after 17 years
'67 International Harvester Scout 800; 345ci V8,T18 4spd, Dana 20 TC
'06 Chrysler 300C SRT8 6.1L
SJZ is offline
post #3 of 17 Old 06-02-2007, 12:12 PM
10achik
I ate what?
10achik's Avatar
Does it do it pretty much when your driving slow turning corners or all the time?
Ken
99 GC Limited - 4.7L HO V8, 6.5" IRO HC LA lift, F&R D44s locked & trussed, 242HD, IRO TC Skid, KMA Bumper, 35's
2006 Saturn Redline -2.0L Eaton supercharged I4, GMPP Stage 2, Custom Tune, AEM CAI, Ebiach Pro Kit w/ swaybars, EVO Ventus V12s (13.76 @ 103.85)
2006 Pontiac G6 GTP
2012 Nissan Juke - (hers)
2000 SV650 - naked, integrated tail light, sliders, corbin, pilot roads, RK chain & sprokets, D&D full exhaust, FactoryPro Stage I jet kit, +4 Ignition Advancer, Barnett race clutch
2006 Triumph America 900 - Full Dresser
January 2009 Grand Cherokee of the Month (GCOTM)
10achik is offline
post #4 of 17 Old 06-02-2007, 12:14 PM
greasefingers
greasefingers's Avatar
1994 ZJ
SJZ has an excellent suggestion here.
Cheers Steve
94 Black Laredo 4-Liter with QuadraTrac (42RE trans & NP249 TC) 200,000 + miles purchased new
88 Cherokee 2-door with 5speed manual 139K miles(deceased) purchased new
greasefingers is offline
post #5 of 17 Old 06-02-2007, 12:50 PM Thread Starter
scudman
2000 FSJ Cherokee
It is a rotating grind. It is quite noticeable at all speeds and the noise rpm increases with speed. No difference going around corners. Interestingly the noise level is more pronounced when accellerating. When I coast it quiets a bit, but when I step on the accellerator the noise increases.
What else could it be besides a wheel bearing?
scudman is offline
post #6 of 17 Old 06-02-2007, 01:39 PM
10achik
I ate what?
10achik's Avatar
It sounds like a wheel bearing to me, I was trying to elliminate other diff problems.
Ken
2006 Pontiac G6 GTP
10achik is offline
post #7 of 17 Old 06-02-2007, 02:27 PM
Cebby
http://www.jeepslimited.com/index.ph...d=22&Itemid=98
For axle seals, but same process for bearings (replaced mine while I was at it)
2000 WJ Laredo 4.0 4x4 Taupe Frost - Stroker | Clayton LA w/3" Lift | 33's on JK 17's | Axles next
Cebby is offline
post #8 of 17 Old 11-17-2009, 11:33 AM
jrjeff
I have a similiar problem
My rear drivers wheel is making a similiar grinding noise. Mine is not speed related. It makes a couple of crunching noises rolling to a stop the last two or three feet and makes a final crack just milli seconds after the vehicle comes to a stop. The garage I took it to says it sounds like the axle. I don't want to replace the axle and then find out that wasn't the problem. Now a piece of the parking brake assembly on the passenger side fell off at the garage parking lot the day I took it to get checked out, but again this is from the driver side. I didn't think about a brake issue until I read this thread. A wheel bearing would be cheaper than an axle. I just don't want to waste money to find we repaired the wrong thing. Please let me know, thanks. Oh it is not the brake pads, they are still thick and I can see them and nothing eating away at the discs or pads.
jrjeff is offline
post #9 of 17 Old 11-17-2009, 12:03 PM
StrokedWJ
StrokedWJ's Avatar
Personally, I'd take it to another shop for a second opinion. The mechanics driving the jeep will have a lot easier time diagnosing your problem than we can over the internet. If the second shop says the same thing, you've got your answer.
2000 WJ 4.5L - Stroked, Locked, & Long-Armed
Looking for 6" WJ springs!
StrokedWJ is offline
post #10 of 17 Old 11-17-2009, 08:18 PM
sandman
scudman, theres no such thing as a 2000 FSJ.
1993 Jeep ZJ. 4.0
sandman is offline
post #11 of 17 Old 11-17-2009, 10:42 PM
StrokedWJ
StrokedWJ's Avatar
He said thanks for the heads up... back in 2007!
post #12 of 17 Old 11-17-2009, 11:58 PM
sandman
LOl........... my bad
1993 Jeep ZJ. 4.0
sandman is offline
post #13 of 17 Old 11-18-2009, 11:39 AM
indept
To answer your question, and I think I'm the first to do so, the bearing is pressed onto the axle. You have to remove the wheel, caliper, caliper bracket, and rotor, then remove the 4 nuts holding the retaining plate. Then the axle pulls out. The bearing is pressed onto the axle. It's a beech to get off and you need a press to put it back on. You also need the press to get it off but you could cut it off with a grinder / cutting wheel. Just be careful not to mess up the axle. The seal is also there, it goes on BEFORE the bearing & lock ring are pressed on. You need a 20 ton press (recommended). Then bolt everything together. The whole thing minus the bearing removal & reinstall should take less than 2 hours. I did my right rear bearing. I have one of these:
- Harbor Freight Tools - Quality Tools at the Lowest Prices
The 12 ton version isn't big enough to fit the axle, at least not for removing the bearing.
2000 WJ 4.0L 42RE 242 TC
190,091 miles & counting
indept is offline
post #14 of 17 Old 11-18-2009, 12:10 PM
StrokedWJ
StrokedWJ's Avatar
Umm dude, this thread is from 2000 freaking 7! I don't think he still needs the answer...
post #15 of 17 Old 11-18-2009, 01:49 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
the e-brake shoes are under the rotor. inside the rear rotor is similar to a drum brake for the parking brake mechanics.
it could very well be the parking brake, sounds like what happened when mine 'sploded a while back.
ratmonkey is offline
247 Rear Output Bearing Replacement Granam73 ZJ Grand Cherokee Forum 2 01-02-2009 08:54 PM
Wheel bearing replacement ScotAusborn ZJ Grand Cherokee Forum 1 07-10-2007 04:32 PM
Rear wheel bearing replacement dino61 ZJ Grand Cherokee Forum 2 09-10-2006 01:02 AM
Rear wheel bearing replacement jjenks0 ZJ Grand Cherokee Forum 6 03-11-2006 04:33 PM
Attempting the wheel bearing/hub assym and CV boot replacement today AWILD ZJ Grand Cherokee Forum 0 01-12-2006 01:38 PM
