rear upper control arm bushings replacement - JeepForum.com
post #1 of 2 Old 08-24-2009, 10:44 AM Thread Starter
itr1446
Well for awhile now my jeep has driven not the best since i lifted always felt alittle weird so today while replacing the fuel filter i looked at the upper a arm bushings and they are totally shot and torn. I was wondering if these are easy to do and i assume they get pressed in? But my other question is, is there better ones on the market like spherical bushings or something? If i had the cash i would be tempted to buy rear long arms but i havent seen anything in the classifieds lately and i cant afford new right now. so let me know what you think the best solution is and how they are in the arm thanks.
2000 wj inline 6 quadra drive with 242 swap
IRO 5.5" front long arm suspension and mx6 shocks
JKS track bar and disco's
OME dual steering stabilizer
itr1446 is offline
post #2 of 2 Old 08-24-2009, 11:03 AM
SDT03GCOverland
2003 WJ
I replaced my bushings (on my ZJ) and what I found helpful was to place the bushings in the freezer while you take your CA's off. This contracts the metal (Makes them slightly smaller) so they slip in MUCH easier. The first ones I did, lower bushings of the lower front CA's were MUCH harder since I had not thought of the freezer plan yet.
2003 Grand Cherokee Overland, 4 inch Rough Country Lift, upgraded to Rusty's Front Long Arm, JKS Adjustable Trac-Bar
SDT03GCOverland is offline
Replacement Bushings for Pro Comp Control Arms? MineRunnerZJ ZJ Grand Cherokee Forum 2 12-17-2013 09:25 PM
Upper Control Arm Bushings shot arsonist_bob ZJ Grand Cherokee Forum 4 07-26-2009 08:08 PM
so i need new front upper and lower control arm bushings Bobbert ZJ Grand Cherokee Forum 8 03-10-2009 05:38 PM
Rear Upper Control Arm Bushings 01GrandFish ZJ Grand Cherokee Forum 0 11-04-2007 05:41 PM
96 ZJ - Are The Front And Rear Upper CA Bushings The Same nbjly ZJ Grand Cherokee Forum 3 10-02-2007 07:25 PM
