Rear track bar bracket - JeepForum.com
post #1 of 8 Old 07-21-2013, 11:27 AM Thread Starter
jtackerman28
So long story shorty my rear trackbar bracket is completely ripped off my axle and ruined is there anywhere to source a new one??
3.5 re lift, double sheer front tb, 31" wrangler duratecs
jtackerman28 is offline
post #2 of 8 Old 07-21-2013, 11:43 AM
jetjr91
Go with an adjustable track bar otherwise you'll end up with the same problem.
eBay should have them though
jetjr91 is offline
post #3 of 8 Old 07-21-2013, 11:56 AM
jetjr91
Maybe I read that wrong. I think you mean the actual bracket welded on the axle. Try tntcustoms.com or ruff stuff they should have it
jetjr91 is offline
post #4 of 8 Old 07-21-2013, 02:23 PM Thread Starter
jtackerman28
Checked both no luck. It's the bracket that has the upper control arm built into it
post #5 of 8 Old 07-21-2013, 02:28 PM Thread Starter
jtackerman28
Yeah I'm ordering a new adjustable one but I can't even find a new stock bracket.
The real reason it broke was because both my bumpstops some how fell out and the bracket hit on the bottom of the jeep breaking it
post #6 of 8 Old 07-21-2013, 03:44 PM
Technohead
Iron Rock has a bracket kit for converting Ford 8.8 rear axle to a ZJ. You might be able to adapt that kit. Or you can make a new bracket.
-Eric
Technohead is offline
post #7 of 8 Old 07-21-2013, 09:21 PM Thread Starter
jtackerman28
I talked to Kolak and he is seeing if they will sell me just the track bar bracket from the kit, also am trying to get it fabbed locally
post #8 of 8 Old 07-22-2013, 07:20 AM
Timo_90xj
Timo_90xj's Avatar
If you can't find one through any of the aftermarket manufacturers, take measurements and fab your own from box steel. It is very easy to do if you have an angle grinder, 10mm and 12mm drill bits and a welder. Half an hour job
***Under construction***
Timo_90xj is online now
