Rear track bar - JeepForum.com
post #1 of 4 Old 03-13-2012, 08:12 PM Thread Starter
labpaws
Rear track bar
Does the rear track bar frame mount bolt need to turn out? Meaning... is the bracket the bolt goes through threaded. I got the nut off and can not get the bolt out. I assumed i could just hammer it out. My torx bit is junk and not able to turn it
labpaws is offline
post #2 of 4 Old 03-13-2012, 08:17 PM
E-rok
its under tension so it wont slide out. I usually thread them out
2011 WK2 Laredo X Hemi
2013 Ram 2500 Cummins
E-rok is offline
post #3 of 4 Old 03-13-2012, 08:29 PM Thread Starter
labpaws
Ok thanks. I would not think it would be under tension with the other end undone. Ill have to get a good quality torx bit to turn it out. I have spring and bump stop bracket off and thought a BFH would slide it out but will not even move
labpaws is offline
post #4 of 4 Old 03-13-2012, 08:34 PM
sebian
The bolt is probably siezed to the sleeve in the trackbar bushing. Pretty common in the salt belt. Mine were like that too. Spray it with a lot of penetrant, and give it a few good whacks with a hammer, or maybe try an air hammer if you have one handy.
1995 ZJ 5.2L V8 318. 230,000 miles and still rollin.
List of parts not replaced yet:
sebian is offline
Cant get rear track bar off please help ! rozco ZJ Grand Cherokee Forum 15 09-02-2011 04:46 AM
Rear track bar jayeepee ZJ Grand Cherokee Forum 3 06-25-2011 11:41 AM
Looking for rear track bar MarkInTombstone ZJ Grand Cherokee Forum 10 03-01-2011 09:57 AM
Rear Track Bar jnjtrevino ZJ Grand Cherokee Forum 3 06-29-2009 03:40 AM
zj front to rear spring 4" lift rear track bar info autobeamhotmail ZJ Grand Cherokee Forum 3 03-01-2007 04:07 PM
